allye 530 3 Cars Posted December 27, 2012 I have read Megane 4pot Brembos (225 sport) fit under SL434's with no spacers, where as 406 coupe Brembos require 16mm spacer. I want to avoid using spacers really (opinions on this?) I would assume the Megane calipers are not a direct fit like the 406 items so a mounting bracket would have to be made? - Whilst we are here what discs would be used with the Megane calipers under the 434's? Many Thanks! (found a pair of reasonable priced megane calipers) Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted December 28, 2012 The thing with M225/C197 calipers is that they have no mounting lugs at all, so you can fit them to any disc you like (or that makes the setup fit under a certain type of wheel anyway), with custom-made brackets. And the caliper body shape is rather different design to 406 Brembos to begin with, which is why they require less space. It only just fits with 7x15" 309 Turbo wheels and whopping 302x26mm 307 CC 180 discs: You might need to use a shim of a few mm's with 6.75x15" SL434's. Hope this helps. Share this post Link to post Share on other sites
allye 530 3 Cars Posted December 28, 2012 (edited) Cheers Nik, whats the opinions on running 16mm spacers? with the 6.75j I don't think its a great option. I don't want to put GTI6 calipers on as I'm a massive tart What bolt on packages are available from the likes of HiSpec, Wilwood and KAD? Edited December 28, 2012 by allye Share this post Link to post Share on other sites
welshpug 1,627 Posted December 28, 2012 there is a Hispec caliper that is a direct lug fit and sits over late 266x22mm discs, not sure if you will get them direct but a lad on a few of the 106+saxo forums sorted them. rallydesign do a 285mm kit with their own rather expensive discs, they do need spacers for 15" 1.9 wheels but not very thick ones. Share this post Link to post Share on other sites
allye 530 3 Cars Posted December 29, 2012 Brilliant, thanks for that WP, just checked out the Hispec website. Looks as though the Megane caliper is a good set up, can you suggest a disc size (car model etc) to use with the Megane caliper under the 434's? I can then give the caliper, disc and a 309 hub to a engeering friend to make up the brackets. Share this post Link to post Share on other sites
Anthony 1,000 Posted December 29, 2012 rallydesign do a 285mm kit with their own rather expensive discs, they do need spacers for 15" 1.9 wheels but not very thick ones. Assuming that's the Wilwood kit that you're talking about, it can be used on a 1.9 wheel without spacers, but typically requires very slight "relieving" of the caliper body with a grinder to prevent it fouling on the inside of the spokes. Share this post Link to post Share on other sites
allye 530 3 Cars Posted December 29, 2012 Not sure I could bring myself to take some chunks out of a very expensive caliper! Share this post Link to post Share on other sites
welshpug 1,627 Posted December 29, 2012 I will have to try one of the wheels on the Saxo without the spacers, might be Garry has SMR's, only thing that puts me off those is that you can only get the discs from Rallydesign, and not cheap IIRC, but a necessity as the 306 discs aren’t tall enough, bringing the caliper closer to the wheel. wilwoods are cheap end of the market, you should price up some AP's or those RS brembo's new... the DS3R uses brembo's, £440 each on Servicebox Share this post Link to post Share on other sites
allye 530 3 Cars Posted December 29, 2012 I was always under the impression wilwoods were a fairly decent caliper? I get hold of these Megane brembos and have a go at fitting those, they look much nicer than the 406 calipers too! I guess I want to be fitting a 285mm, approx, disc to ensure they fit under the 434's nicely? Share this post Link to post Share on other sites
Batfink 201 Posted December 29, 2012 Wilwoods are cheap. Some are known to have flexing issues Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted December 29, 2012 I guess I want to be fitting a 285mm, approx, disc to ensure they fit under the 434's nicely? Disc offset and caliper width is more important, as that's why you'd need spacers in the first place. Share this post Link to post Share on other sites
welshpug 1,627 Posted December 29, 2012 and caliper position within the wheel, going smaller with the disc will move the caliper closer to the hub of the wheel, looking at the pic of the SL434 it looks in the ideal location. that or get a belled disc and shift it inboard. Share this post Link to post Share on other sites
Baz 421 Posted December 29, 2012 The thing with M225/C197 calipers is that they have no mounting lugs at all... Aren't they just a traditional radially-mounted caliper rather than 'lug'-mounted? Wilwoods are ok, for the money especially, but they're never going to be the best, but then as said, weigh up what AP's/Alcons etc would cost... These are my old Dynalites that cleared 1.9 Speedlines with a 3mm or so spacer; http://s49.photobucket.com/albums/f255/205gtmi16/FS/Wilwood4pots/ & I have these Midilites, they clear, just, without spacers; http://i49.photobucket.com/albums/f255/205gtmi16/205%20White%20APN/F7BB7963.jpg Share this post Link to post Share on other sites
allye 530 3 Cars Posted December 29, 2012 This is rather confusing. Surely I am restricted to what width disc I can run by the caliper?If I was to run the 302x26mm 307 CC 180 discs I theory i would only have to use a 5/6mm spacer as its a tight fit under the 15x7j SL's. Plan is forming! Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted December 30, 2012 Yes, your calculations seem fine.They are designed for a 28 mm disc, but running a 26 mm one will be fine.But there's also disc offset or height to take into account, which is what I meant.Less offset/height, means the disc braking face is closer to the wheel face, which in turn means that the caliper will have to sit further outboard as well - finally meaning that you'll need wider wheels, wheels with less offset/ET or wheel spacers. Share this post Link to post Share on other sites
Baz 421 Posted December 30, 2012 SL434's are 6.75". Share this post Link to post Share on other sites
allye 530 3 Cars Posted December 30, 2012 SL434's are 6.75". I know! I was referring to the 309 Turbo SL's which are 7j and require no spacer but are very close fit, with the 434's being .25' narrower I will need a 6mm spacer at the most using the 302x26mm 307 CC 180 discs Yes, your calculations seem fine. They are designed for a 28 mm disc, but running a 26 mm one will be fine. But there's also disc offset or height to take into account, which is what I meant. Less offset/height, means the disc braking face is closer to the wheel face, which in turn means that the caliper will have to sit further outboard as well - finally meaning that you'll need wider wheels, wheels with less offset/ET or wheel spacers. Indeed I had worked out that the offset of some discs are drastically different to others, in theory if I copy the above use of disc it should work out, in practice? - We will have to wait and see! Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted December 30, 2012 I've these calipers and a brand new pair of said discs as it happens, but unfortunately no exotic Speedlines to hand. Share this post Link to post Share on other sites
Baz 421 Posted December 30, 2012 I know! I was referring to the 309 Turbo SL's which are 7j and require no spacer but are very close fit, with the 434's being .25' narrower I will need a 6mm spacer at the most using the 302x26mm 307 CC 180 discs Ah I see! What offset are the 7" ones, the same? Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted January 2, 2013 http://forum.205gtidrivers.com/index.php?showtopic=140773&p=1268844 Share this post Link to post Share on other sites
