custard-rallye
306 Rallye 8V Turbo
custard-rallye
well since i sold my lazer green turbo i miss it like hell (bloody females) and have come across a cherry red 306 rallye with a 8v turbo spec is
paddle clutch
air filter
evo intercooler
and full exhaust
brembo brakes
t/d pro race 1.2
and lowered
only question i have is the car is running 17psi of boost is that safe on that engine
and the owner says it has flat top pistons which are better??
any help would be great
sean-G
hello mate
1.2bar ?? is it on aftermarket management? as far as i know 1.0 bar is has far as you can go with out fuel/ing cut off (thou you can upgrade the map sensor in the standard 3.2 ecu-(erasers 205 tct) for example )
flat top pistons came in the citroen xm turbo lumps (i think lol) people say you can run abit more boost safely with these pistons.
custard-rallye
It has the boost cut removed and ecu unlocked
The 406 engine I did had flat top's too, good old PSA engineering no doubt, As many people know on here I think it is the worst engine PSA ever made, great if you like 5th gear motorway work or it's like driving a Derv, Compare on to a good Turbo conversion and there's no comparison, If anything you want lower compression with the fuel these days unless it's been remapped
custard-rallye
I have a dta sitting worth it ?
Having used a Omex on one and got good figure's, the power delivery is just wrong, It was a stop gap engine until the 16v units came on board and unless you use a bigger turbo I doubt you'll see much difference in the way it drives
