Iain-gti 6 Posted November 30, 2012 Hi, I'm looking at getting wheel stud conversion but there's two lengths 60mm & 80mm which one? I'm running team dynamic pro wheels with no spacers. Pretty sure from memory they should be tapered nuts. Regards Iain 1 Share this post Link to post Share on other sites
AlexRS2782 136 1 Cars Posted November 30, 2012 From memory the TD Pro Race wheels require a 60degree tapered setup. That's the taper used on the 1.2's on my Saxo VTS and also the same taper used wth the wheels on a Ford with the same bolt pattern. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 1, 2012 Without spacers a 60mm stud is long enough to use the flat face open nuts on standard wheels or any in a suitable offset, 80mm studs are only needed if you are running wheels with spacers. If you are only using wheels that take a taper seat nut, a 60mm stud will be plenty long enough. g Share this post Link to post Share on other sites
Iain-gti 6 Posted December 2, 2012 Thanks for the reply I have ordered 60mm Share this post Link to post Share on other sites
