Yves
206 Ecu
Yves
Hello boys, sorry to ask here, tried to find elsewhere, but found nothing.
Friend of mine swapped TU3 KFX engine in 206, he is now using TU5 NFZ from Phase 1 306, unfortunately he bought engine without any Engine loom and ECU. He bought than totally torn engine loom and good ECU, originally from 206 that could suit perfectly. After loom soldering (hope to wrote it well) and immobilizer shutting off engine once started run about 5 minutes and since that never started.
ECU was sent to immo check, but the guy is not responding. So we are looking for new ecu, but is hell big problem to find one in CZ, after all NFZ engine 206 used only one or two years :-(
My questions are:
1) Is it possible to use Phase 2 306 NFZ engine or TU5 100hp ecu? Nobody knows here :-(
2) What could be the problem of not running engine? Seems that fuel pump was without power. Could be the problem badly repaired loom and blown ECU?
Edited by Yves
