dexter1002 4 1 Cars Posted November 21, 2012 Hi there, I after a bit of info regarding a gearbox on my gti6 conversion I'm doing, I know I need a box with the capabilities of holding the cranks sensors which my early 1.6 be1 does not have. Will the later be3 1.6 boxes still accommodate my drive shafts? Or should I go with a 1.9 box and change hubs, drive shafts, brakes ect? Thanks dexter Share this post Link to post Share on other sites
rikky 37 Posted November 22, 2012 i'm using a be3 1.6 box on my 205 gti6. i've still to put the box on, but i've got a crank sensor that came off it. it's a lot skinnier than the standard gti6 be3/6 one, but i'm sure it will be fine Share this post Link to post Share on other sites
stef205 91 1 Cars Posted November 22, 2012 A gti6 box is a be1 box, if you used a be3 box you'd have to change some linkages etc, you should be able to find a be1 box with a crank sensor hole. (null) Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted November 22, 2012 (edited) I've got a BE1 1.6 box for sale up the road in Somerset with a crank sensor hole. Edited November 22, 2012 by chipstick Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 22, 2012 as said a GTi6 box is either a BE3 or BE4 depending on age, BE1's of 3 types but around 1987/8 had the crank sensor hole fitted Share this post Link to post Share on other sites
pug_ham 240 3 Cars Posted November 22, 2012 A gti6 box is a be1 box, if you used a be3 box you'd have to change some linkages etc, As above, the GTI-6 box is either a Be3 or Be4 depending on age & to swap between the Be1 & Be3 does not need any linkages changing, just the clutch pedal, cable & release bearing are different. Other than that, a Be3 will fit straight on from a later 205 & should have the CAS hole. g Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 13, 2012 Okay so I have given it some thought and I'm going to go with a Xsara vts box on my gti6. The only thing I would like to know is what would I have to change from my box to the Xsara box? What are the differences in the clutch pedal between be1 and the Xsara? I bought a servo and m/c a while ago and my old clutch cable went on so I'm guessing this is still the wrong pedal? I'm just after everything I would need to changed as I do motorway miles and I don't think the 1.6 box would be best for this? Thanks and any help would be greatly appreciated D Share this post Link to post Share on other sites
pug_ham 240 3 Cars Posted December 14, 2012 If you presently have all Be1 cable & clutch mechanism, to swap to a Xsara VTS box you'd be best suited to change everything to the Be3 push clutch & cable set up, including the Xsara box clutch fork / arm & bearings to suit. To do this you'll need a Be3 clutch pedal, cable, release bearing, clutch fork / arm & bearings. You only change the motorway cruising rpm by about 100rpm iirc between a Xsara VTS / Mi16 box & the 1.6 GTI box but I suppose every little helps. g Share this post Link to post Share on other sites
dcc 855 Posted December 15, 2012 Iirc you need a 205 diff in a xsara box. Or xsara inner shaft cv. Share this post Link to post Share on other sites
welshpug 1,623 Posted December 15, 2012 (edited) you can mod the pedal easily, and its a post 1990 thing, i.e MA boxes had the later hook type as well. Edited December 15, 2012 by welshpug Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 15, 2012 you can mod the pedal easily, and its a post 1990 thing, i.e MA boxes had the later hook type as well.Is there any pictures floating around of the be3 type pedal? I could mod mine then as its out the car at the moment Thanks Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 15, 2012 Are the vts boxes be4? If so what you have said to changed will still work yes? Thanks Share this post Link to post Share on other sites
welshpug 1,623 Posted December 15, 2012 yes, the differences are internal, clutch works the same way on a VTS box, other BE4 boxes have different types. Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 15, 2012 yes, the differences are internal, clutch works the same way on a VTS box, other BE4 boxes have different types. That's cool there is one for sale on the gti6 forum and I just wanted to know before I purchase it. Thanks Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 26, 2012 Would I use the normal vts clutch with the vts box then and not the bx 16v one that was previously going to be used for the 205 box? Cheers Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 26, 2012 And if I use the bx16v clutch would I have to change the release arm to a be3 item or can I keep the existing vts box arm and use vts clutch with my be3 pedal and cable? Just need to know as I'm buying the clutch tomorrow Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 27, 2012 205, 405 ph1 & BX16v clutch's are push, xsara's and anything performance wise from 1993 ish are pull and all use corresponding parts so for furture referance 205, 405 ph1 & BX16v use a push clutch (3 piece) with matching push arm 405 Ph2, Xsara VTS, 306 S16 on use a Pull clutch (2 piece) with matching pull arm Also make sure you use the right colour bush's top and bottom for the arm as they can be different locations causing the clutch not to work well and or fail quickly Share this post Link to post Share on other sites
dexter1002 4 1 Cars Posted December 27, 2012 Brilliant thanks alot miles I went for bx16v clutch, be3 cable and be3 pedal so I just need the release fork/ arm and correct bushes. Will post in the wanted section to see if anyone has one. Thanks ! Share this post Link to post Share on other sites
