sean-G
Engine Noise Advice Needed (Pinking?)
sean-G
evening all
my engine doesn't sound very healthy at the moment.its got a very worrying noise and has sounded like this since i bought it(around 3months ago/not been used on the road yet thou has been driven around an industrial estate and drives great!)
it sounds like its pinking to me so i filled it with 97RON and retarded the ignition.i retarded the igntion so much so that the car was noticeably down on power, but it made no difference to the speed or sound of the noise.
does anyone know what the noise could be? 2 points to mention thou the exhaust manifold has a hairline crack & exhaust valve clearances are abit tight roughly by 000.2
^could these possibly be the cause of the noise,i have also heard the injectors can be abit noisey.
small video of the engine idling
sorry about the noisy alternator lol
any help would be much appreciated.
cheers
dcc
could be a cracked exhaust manifold, quite common.
lemmingzappa
Sound could be leaky manifold/exhaust or the injectors. I had a pretty bad pinking issue which wouldn't disappear regardless of advance.
After 2 different distributors I ended up having to get one rebuilt to fix the problem.
