nour_peugeot
Installation Powersystem Box
nour_peugeot
hey every body
i need your help ... i got the power system box and i have't diagram manual to Install it
in my peugeot 306 with 2.0 16 v engine xu10j4r
and i search for it and i found nothing
if any wan can help me by tha map or diagram or montage
Err, what is it and what does it do?!
dcc
who is your daddy, and what does he do?
By the looks of it you;ve been had by the old resistor chip in a box, just makes the car overfuel
matyasg
OMG, 380EUR!?!
take it back and ask for a refund..
Fairly sure he's taking the piss out of you.
calvinhorse
Phwoooooar! They put it in a box!
I think it goes up your ar..........s...... .. .
nour_peugeot
it's like a chip
vide.gifpuce.gifPower Ch 13 max. vide.gifpuce.gifCouple + 2 million kg max. vide.gifpuce.gifN / m + 20 Nm vide.gifpuce.gifType of connectors Solder vide.gifpuce_verte.gifWith SFI module + 8 Ch max
and i can't get it back coz i leave in egypt so hard to back it
and i don't know how to install it .... there wasn't and thing about install in website
d7ve_b
Lay the back seats flat, it'll help maximise the effect of this mod.
dcc
send it back...
nour_peugeot
i got the install map
and soon i will test my can by dyno
but now i looking for upgrade my engine
thanks guys
please don't!
EZ Tutty
on XU10J4R bosch engine management....
Pin 25 - Coolant Temp Sensor
Pin 2 - Earth
Pin 29 - Throttle Position
Pin 27 - Intake Air Temp Sensor
I personally wouldn't bother, it's a generic IC inside the unit which is just adding offsets to the CTS, TP & IAT sensors 'tricking' the ECU into running differently, it's almost completely random and could potentially cause damage to your engine, the proper way of doing this is a tried and tested remap from a reputable company.
Edited by EZ Tutty
GLPoomobile
I wonder how many times somebody has to be told not to do something silly, when they've already invested wasted several hundred euros on a bad decision :blink:
Perhaps we could formulate an equation about this :D
Donate it to the forum and get an electronics guru to pull it apart and publish findings.
wicked
Probably it will mimic a lower inlet temperature and lower CTS at higher loads, to increase fueling.
Maybe also mimic a lower load index to advance ignition and compensate the fuel with the sensors above.
But for 380 euro, total rip-off...
If you want to play with sensor data, better buy a Apexi s-afc, that allows you to program it your self and mod the MAP sensor data as well.
nour_peugeot
guys i try it now and before power system
before power system i got 0-100 in just 9.2 sec
after power system i go it in just 8.5 sec
in the same road and same time
any one think i will got a problem in my engine ?
omega
i think a old english saying comes to mind
flogging a dead horse.
Yes, even with bad remaps you can have engine issue's, Mind each day and every run you do you will end up with different times
