m@ttc 30 Posted November 4, 2012 hi im looking at repairing an hole in the block, the hole is for mounting the gearbox, 4 holes in total one is stripped of it threads, possibly when i got one of these cheep clutch repaire centres to change my cluth last time, they also managed to brake the plastic arch trim too anywho my question is an m10 helicoil the internal diameter or external diameter? im looking at these and wondering if there the right ones for the job? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120996761686 Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted November 4, 2012 The size is the nominal size of the threaded bolt that the insert suits. The bolts from engine to gearbox are M10 standard pitch which is 1.5. Those you linked to are fine pitch (incorrect). Also that link is just for spare inserts, on their own they are no use unless you have the drill and special tap that goes with them. eBay item no 260927163479 is an example of what you need to do the job, along with a drill of some sort and a tap wrench. Share this post Link to post Share on other sites
welshpug 1,737 Posted November 4, 2012 M10 is the thread size for the fastener going into it. Which hole is damaged BTW? personally I'd try and get a timesert in there as they are stronger but I'm not sure there would be enough meat on the lower front corner for one to be used. Share this post Link to post Share on other sites
m@ttc 30 Posted November 4, 2012 its the hole with the bolt sticking out, i can get the tap and insert tool from work no problem just i need a longer tread than the ones at work the only got 10mm long ones. Share this post Link to post Share on other sites
m@ttc 30 Posted November 4, 2012 thanks for the replies guy's i think im gonna go m10 X 1.5 2D, if this is correct. I dont know what a timesert is would this be a better option then? Share this post Link to post Share on other sites
welshpug 1,737 Posted November 4, 2012 http://bit.ly/RzjgAZ Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 4, 2012 Helicoils are cr*p compared to Timeserts, Not the cheapest option thou as a kit mind I use Wurth ones start around £75.00 up Share this post Link to post Share on other sites
Rippthrough 98 Posted November 4, 2012 Helicoils are fine when fitted properly. Hence the billions of them in aircraft. 1 Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted November 5, 2012 http://shop.grfasteners.com/epages/es116900.sf/en_GB/?ViewAction=View&ObjectID=7867417&Page=2 Bottom of page. M10x1.5 kit, everything you need to do it. Share this post Link to post Share on other sites
Mad Professor 7 Posted November 5, 2012 As said above, I would not bother with Helicoils, I use Timeserts eveytime I need to replace a striped thread. Share this post Link to post Share on other sites
jamie_1992 66 1 Cars Posted November 5, 2012 why not drill it out and tap a new thread in? Share this post Link to post Share on other sites
welshpug 1,737 Posted November 5, 2012 you can't tap what does not exist. Share this post Link to post Share on other sites
jamie_1992 66 1 Cars Posted November 6, 2012 You can tap a hole if you drill one? Share this post Link to post Share on other sites
