Harrisrallying
Be3 Crown Wheel And Pinion
Harrisrallying
Hi hope someone can help I have a 1.6 gti with a be3 gearbox I want to get a final drive as close to 5.1 does anyone know wat I can get the crown wheel and pinion out of to hopefully get this
brumster
Citroen Berlingo/Peugeot Expert van, if you can find the right one... non-turbo diesel models before about 2001, if I remember correctly? You're after the 15x76 final drive (5.06:1)... bit rare I think ;)
edit: there was also a 4.9 (15x74) in the XUD9. The 5.1 shows up on the "1580 SPI" model (1600 petrol?) and DW8 model, according to my list, so maybe not a diesel at all...
Edited by brumster
You need to watch out, the 4.8 I have is different to the early BE3's, I had to use a BE4 gearset on mine
cybernck
Sorry to jump on your topic, just want to ask if BE1 CW&P is of any use in a BE3 box?
Upto around 1997 yes the CWP's are all the same
cybernck
Great, thanks.
Harrisrallying
Thanks for the response so I'm thinking take a chance on a berlingo box and see whats in there im guessing there is no way of finding out the ratio without striping the diff cover off ?
brumster
Oh yes, I'm not talking about PTS/Quaife 4.8's (16x47) here.... quite agree.
Edited by brumster
brumster
I believe not, no, I don't think the gearbox codes go to that level of detail. The chassis number possibly helps identify it but I don't know how to decode, sorry.
Yeah, find the code and look on servicebox.
brumster
Servicebox lists the 15x74 (4.9:1) against the 1.8D model (parts 3103A6 and 2316K2). Lists prices but suggests alternatives; if I recall last time I chased this a few years ago, one of the items (either the crown wheel or the pinion) was no longer available - forget which one.
But it does re-enforce the idea that if you can find a naturally aspirated 1.8 diesel van, you're in with a good chance :)
1.6 307's have a 4.9, same one mentioned above.
EW10 308's have 5.06, as do 100hp 8v picasso's.
if you want to go really really fast, 207 has a 3.3 FD :lol:
looking at the prices, you're not far short of a bacci romano f/d for a be3/6! :blink: and more than their 5 speed ones.
Edited by welshpug
brumster
That's Baz's favourite diff. He fits that to all his cars ;)
:lol:
:lol:
from memory that came from the eco model they have done, 10mm lowered, no spoilers, smooth body, eco shift light, and long gears.
Harrisrallying
Will all these fit into a be3 box
brumster
Mine are all out of BE3/4 or 3/5 boxes, yes. I'm guessing the others are too, welshpug knows his stuff and I don't think he'd suggest them if not.
You need to watch the year as I have said above, The cross over date isn;t that clear on them
afaik its just the end bearing that was changed on the pinion shaft, the shaft itself is the same diameter, this affects the casing more than the shafts you use.
I'll ask Garry, the Rallydriver I service for, he's had half a dozen BE4 boxes apart recently in building one for his Saxo.
Edited by welshpug
