joed66
Gti Quick Shift On An Xs
joed66
Basicly i have a 205 xs but cant find a quick shift gear lever for it does the gti one fit or if not does anybody no were i can get one for my car
allye
The L bracket on the the sub frame is quite different so thats a no go, what you can do is get the bottom on the actual gear lever extended to shorten the throw, this is a picture of a XU lever (different but same idea)
If you do go down this route be sure to get a skilled person to do the welding, I had a engineer/fabricator do mine so I knew it wouldn't break!
To add you may need to invest in some adjustable, uprated linkages as extending it would change the mounting point slightly.
joed66
Cheers i need new linkages anyways the ball joints on mine as a tiny bit loose you could say.
