PhilNW
Dodgey Starter
PhilNW
Got a problem with the starter, it was clicking intermittently so put a new one on did not cure it, eventually traced it to a dodgy connection under the dashboard (courtesy of the previous owner) giving only 6 volt supply to the starter. Now OK when cold or slighlty warm when hot nothing not even a click, any ideas ?
Edited by PhilNW
Richie-Van-GTi
very common fault, run a wire direct from position 3 on the ignition switch to the starter solenoid.
