Iain-gti
Oil Spray Bars
Iain-gti
Hi,
My Gti6 engine has different cams in that hit the oil spray bars, do i have to use the spray bars or can i just remove them,
Iain
depends how much they are fouling by, you could squeeze them so they clear.
Iain-gti
squeeze meaning bend???
no just squeeze, make them slightly flatter.
Iain-gti
ok there touching more than that
Josh_Quant
picture?
Iain-gti
ill get one friday.
Remove them, Just block the feed hole up
Iain-gti
Do I not need them to lubricate the camshafts. What's the purpose behind blocking them surely if I leave them oil will just squirt out of them.
16v205
Ive removed the oil spray bars completely from the head and blocked the oil feed holes used to supply the spray bars. There will be plenty of oil spashing about from tappets to lubricate the camshaft lobes.
You could leave them open I guess, its your choice but mine are blocked. My reason for this is leaving them open would be a point of little resistance in the oil channels, if that in turn makes a noticable difference to oil supply or pressure to the rest of the head including tappets I dont know, so it got blocked.
Rich
It's no big issue not having them. The XU10J4R doesn't have spray bars, yet is near identical.
Iain-gti
Thank you for the replies!
