mikeamtrak 0 Posted September 24, 2012 I Hope someone has come across this and can help me out? My front windscreen washer is not working, when i pull stalk the wipers work but no motor, I have tested the washer motor (direct to battery) and it works fine, so i bought new stalk and exactly the same, so i cleaned contacts that connect to washer motor and now when it is connected and you pull the stalk, if you disconnect from washer motor the wipers work when you pull stalk????? I am stumped can someone help or is it just easier to run direct from battery but with switch to do manually , i am sure this will get through mot but not ideal??? Mike Share this post Link to post Share on other sites
welshpug 1,737 Posted September 24, 2012 poor earth or corroded terminals in the plug are most likely candidates given the wiper relay is triggered fine and the motor does work. Share this post Link to post Share on other sites
mikeamtrak 0 Posted September 24, 2012 I have connected earth directly to battery and still the same, i have cut the connector off and wired directly to wire and still the same!!! doing my head in now Share this post Link to post Share on other sites
m@ttc 30 Posted September 24, 2012 could still be that the relay is at fault, as the pump and wipers are different contacts within the relay. swop the relay for a known good one before buying anything else. or like welsh pug says bad earth or dodgy terminal terminations. If you have a mulitimeter check for voltage at the pump when you pull the stalk, if not get one you can pick em up cheep for doing simple car electrics and a haynes manual for the diagrams theres pdf's of them around if you have a quick look. Share this post Link to post Share on other sites
welshpug 1,737 Posted September 24, 2012 there's no relay for the washers. Share this post Link to post Share on other sites
mikeamtrak 0 Posted September 24, 2012 Can u tell me which is the wiper relay and is there anymore on the car I can swap to see if it is at fault? Share this post Link to post Share on other sites
m@ttc 30 Posted September 24, 2012 oh yeh my bad pull stalk pump operates, let go of stalk pump stops, simpless not likly to be any thing else thats not been mentioned then. unless youv'e been messing around the fuse boad and pulled the plug out. Does your horn work? Share this post Link to post Share on other sites
mikeamtrak 0 Posted September 24, 2012 Yes horn works, so what do u think it is? Share this post Link to post Share on other sites
mikeamtrak 0 Posted September 25, 2012 does anyone know if there another relay on the 205 gti that works the front washer wipe? Share this post Link to post Share on other sites
welshpug 1,737 Posted September 25, 2012 the only relay there is is for the motor, the washer is direct. Share this post Link to post Share on other sites
mikeamtrak 0 Posted September 25, 2012 Ok thanks.....it has to be a short in the live feed then I presume? Share this post Link to post Share on other sites
ade 4wd 11 Posted September 25, 2012 Check the connection between the fusebox and the washer pump. Looking at the fusebox on the left hand side, there is a seven pin connector, pin 1 goes to the washer motor (it will have number 87 on the wire) Share this post Link to post Share on other sites
205kenny 7 Posted September 25, 2012 Have you checked your getting power (12v) to the pump? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted September 28, 2012 Have you tried a different column stalk? The micro switch can fail meaning the wipers will still work when you pull the stalk but not the washers. If all the wiring is fine then try a different switch imo. g Share this post Link to post Share on other sites
Arsecati 0 1 Cars Posted October 23, 2015 ​Hello all! My first post - so please go easy on me! I know this is an old post, but I see there didn't seem to be any resolution on it, and I have the exact same problem.Wipers are fine, rear wash/wipe fine, but no wash/wipe from the front and no sound from the motor, so I just assumed it needed another. Off I went to eBay and bought one. However, it turns out it's NOT the motor, and in fact, it has turned up some very peculiar behaviour instead.When I disconnect the wires from the washer motor, the wipe function of the wash/wipe action starts working again (sweeps back and forth 3 times). But when I plug it back in again - nothing: no wash OR wipe! As I said, the motor is fine (I tested the old and the new to a battery, no worries at all, and even powered it in situ, and it will pump water out of the jets too). But it seems bizarre that the wipe motion will work if disconnected from the washer motor, but when reconnected, there is zero life at all!Anyone any ideas?Cheers guys!Garry Share this post Link to post Share on other sites
jackherer 543 Posted October 23, 2015 The plug and wiring for the motor is probably corroded, cut it back until you find bright shiny copper then splice new wire in using something like a solder sleeve. Don't be surprised if the wiring is dark and crispy/crumbly most of the way to the bulkhead! You can test it by checking for voltage at the motor plug when the stalk is operated. Test it with and without the motor connected, chances are you will see battery voltage with nothing connected but once the motor is plugged in the voltage will drop a lot due to the resistance of the old wiring. Share this post Link to post Share on other sites
