iPlod999
Driving Lights Staying On.
iPlod999
All of a sudden tonight. When I turn on my dipped lights, normal headlights, my driving lights come on. But my headlights stay on only as side lights.
If I select full beam all lights come on. Headlights on full beam.
When I go down to side lights the driving lights turn off.
When I select full beam I don't get the 'double click' to put them on and off. They go one and off one one click.
Hopefully I will just need a new light stalk.
Do you think the same of could it mean more?
Paul_13
Give your earth blocks a wiggle, the ones in the engine bay near the headlights.
I had the same problem recently and turned out to be the earth block being severly corroded
iPlod999
Cheers Paul_13.
Gave the plugs a good clean and it's almost sorted.
I now have the driving lights staying on for about 2 seconds after I turn off full beam on the light stalk.
Any ideas anyone?
Regards.
Paul_13
Still sounds like an earth problem.
I had a broken wire on my headlight plug which caused the driving lamp to do odd things. Fixed that and it sorted the problem. Earth problems are mind boggling
iPlod999
Cheers again Paul_13.
Need to use the car tonight. So I'll give it some time during the week to have a good look.
