calvinhorse
Engine Swap- Diesel Turbo 1.9
calvinhorse
Whats the little pipe to the intercooler? looks like it goes to the fuel pump?
deathbringer929
boost compensator? does this allow extra fule for when its on boost, i think?
calvinhorse
Cheers Paul. So it wants plumbing back into intercooler / boost pipe..? It's full of oil :D
She's coming along well.. Big ideas for the fmic
For future reference:
rear lower engine mount is same as xu10.
Xu10 s16 engine alternator mount mount fits.
I think the crank pulley is bigger than a petrol to gear up the alternator.
Correct, without it the engine is really flat on boost, as I found out one day when I left it off my old 306.
calvinhorse
So just plumb it back anywhere in the boost circuit or specifically into the intercooler?
there's a specific takeoff for it on the front of the top mounted intercooler.
calvinhorse
Sorry, I'm putting a fmic on.
Any idea which clutch pedal I need?
Edited by calvinhorse
calvinhorse
Any idea what the sensor on the back of the block pointing at the flywheel is? Looks like a crank position sensor?
Also what is the little switch on top of the Lucas pump? It's activated on full throttle?
It is a kind of crank sensor, it is to make the diesel rev counter on the dash work.
Don't know about the diesel pump switch sorry.
Egr switch, you can take that off :)
calvinhorse
Thanks chaps!
I wish I'd bought an older engine :-/
