Andrew C
Rattling Windows
Andrew C
If I close the door when the window is fully down it rattles as if it is loose and there is nothing holding it in place. Before I take it apart is there some sort of guide or clip that may be broken and I need to obtain ? It also happens on my 306.....
GLPoomobile
The window guides are probably loose. It's all fairly self explanatory once you've got the door card off, so nothing to worry about. Just take a look and check all the bolts in the door skin first of all, and if they are all tight wind the window up and down whilst watching the mechanism, give the door a few thumps, and see if you can figure out what's rattling.
Andrew C
Thanks for the advice will take it apart on the weekend and have a look cheers
