scoop
Just Need To Know
scoop
mi16 1.9 3 row - 928 401 304 is it the 160 hp??
cammmy
Does it have a cat? Are the 160HP models the D6C's up until they got cat's?
imaS
Yep, alloy block 1.9 16v 160hp=D6C, no cat. Alloy block 1.9 16v with cat=DFW 148hp. Iron block 2.0 16v with cat=RFY 155hp.
petert1345402284
Never heard of that part number. The other guys are quoting the 3 digit engine code, riveted to the block. The 160hp 3 row Motronic ECU would end in 354 or 355. The 148hp ends in 158 or 161.
eg
0 261 200 355
scoop
eg
0 261 200 355
Erlend405Mi16x4
eg
0 261 200 355
you have the part nr, of the plug there, the ECU part nr. is centered on the ECU-casing. so you probably gonna need a mirror or unbolt it to read it. :)
scoop
eg
0 261 200 355
thanks for the info, i will check it
