harryskid
The Quattro System
harryskid
Might be of interest, some clever stuff!
For "modern" quattro yes, but the originals were 50/50 torque split.
Isn't it just another Haldex system?
d7ve_b
Torque vectoring = rapid destruction of discs and pads :lol:
I believe it might be audi's own take on the haldex systems, volvo have used much the same system on the s60R for some time.
d7ve_b
My S3 runs the hadlex system but it's much cruder than this slick looking set-up. The Gen1 haldex on my car can only run a max of 50/50 distribution, 90% of the time it's FWD. Despite it's crudeness, it is awesome in the wet/snow.
Cameron
Clever! :D
It's similar in principle to a Salisbury diff (i.e. plate LSD) and is a mechanical unit, whereas the Haldex Coupling uses hydraulic pressure to bias torque and is controlled electronically. It looks like a cross between a Quaife ATB and a Salisbury, in that it uses gears that have a tendency to bind when rotated to apply torque to the pressure plates of the front & rear outputs, depending on which side is spinning.
Torque Vectoring is a clever way of getting around the need to have an LSD at each axle, so saves a huge amount of cost! It does kill brake life though! :lol:
that'll be why they have such massive braking capacity then, 365 x 34mm :blink:
Edited by welshpug
d7ve_b
They look like cheap discs....NOT!
