Karl
Extracting More Power From My Gti6 (220+ Bhp)
Karl
hello,
had a lot of help recently from you guys and am now seeking a little more ;) ...
i am looking to gain some more power hopefully upto the 250 mark but anything over 220 is fine BHP tht is :)
any sugestions on what i could do to get this kind of power from my gti6,prices aswell would be very much appreciated. ^_^
currently the only mods i have is a lightend flywheel and a k and n airfilter with a sports back box fairly standard tbh <_<
all comments and opinions welcome would just like to gain some insight to the approxamite cost of this project and a realistic power gain for my money :)
thanks in advance
Karl,
rallyeash
Engine?
My 2.1 16v gti6 engine could be forsale, 230hp na built by sandy brown
Karl
what condition? how many miles? what mods? will it just drop straight in? how much?
thanks
karl,
rallyeash
Covered about 2k since being built 2 years ago by sandy.
Will drop straight in if you buy my throttle bodies, loom and management too!
Not sure on price, depends how much stuff your after
rallyeash
Mods are
88mm steel crank
87mm forge pistons
Custom steel rods
Cat cam 109's
Jenvey bodies
Dta e48 ecu
chipstick
What is your budget?
Anulfo
im guessing to have an engine professionally built to ash's spec then you probably will be around the 10grand mark??
Karl
my budget is sort of unlimeted im pricing this up to see how much im going to need to get the power i crave.
i dont think your loom will fit as mine is a phase 1 205
do i need your throttle bodies and as i already have a gti6 conversion
rallyeash
Na the loom is just the engine loom to run the Ecu which you'll need if tuning yours.
Well you don't need bodies but wont make the power without them.
Karl
are your throttle bodies a carb conversion then yes?.....
...how much are we talking????
no, they are throttle bodies.
chipstick
Can I suggest perhaps having a read up on a few project threads to gain an understanding of the options available.
I think you will quite soon see if this is a realistic acheivement or not.
Forgive me if I come across as negative, but you need to learn the options available, how they will work for you and the realistic pricing involved.
What do you want the car to do? Are you looking to compete at all, 90% road driving, the odd track day? Delivery of the power is something you need to think about.
Also, be realistic with your unlimited budget. For a start, take your car somewhere and get them to sort your loom out, may cost you a couple of hundred, but that's a drop in the ocean to what you are ultimately going to end up spending reaching your goal.
For example, a supercharger kit will get you your goal. You may see a fitting kit for £800 and a supercharger for £1500. This isn't the end of your expenditure.
I am unaware of your car spec, but with the power, are you looking for it to handle? There's a couple of grand extra there if you wish to have a decent diff for example and some choice suspension upgrades.
Basically allot of money, You'll need to make sure the car's suspension and brakes are up-to the job (Don't want to sound harsh)
3 routes,
1. N/A Tuning which won't be cheap (will sound good thou),
2. Turbo Charging
3. Supercharger, the latter if not the best is the cheapest route to go as they are in kit form ready to bolt on
To give you an idea GTi6 on carb's makes around 170 > 175bhp no matter what anyone say's.
I would do it with a cubic capacity increase and throttle bodies. More cubes means you have to rev it less to make the power desired, which helps keep the cost down. With 87 bore x 88 stroke you'll make 220hp easily.
kyepan
Having a car with a higher peak power won't necessary make it any quicker overall....
You could slap in a wild cam, solid lifters, very thin head gasket and enlarge the valve cut outs, then rev it to the moon, and you'd make 230 bhp, but you would have sod all torque everywhere else.
For example if you made it make 142ft lbs of torque ar 8500 revs. That would be 230hp.
But it might then only have 100-120 ftlbs until you get to 5k rpm before the harmonics of the cam kick in. So I'm agreeing with peter
(dons flame suit)
Edited by kyepan
brumster
If you want 250 horses from 2 litres then, as said above, it's going to be expensive. Fancy internals, head work, lairy cams and inlet/exhaust work to match, and you'll end up with a screamer that will go well when it's on the boil - maybe some people who had a razz around in my car at Curborough can testify. BUT, for a road or track car not trying to keep to class regulations ;) then Peter's suggestion of a capacity increase, or even turbo charging, would be a cheaper way to power AND torque and a lot more accessible for a road car.
rallyeash
capacity increase for a good all rounder deffinatley :)
BlueBolt
Turbo!!
Forge the internals, custom manifold and big turbo, into ITB's!!!
Awesome!!!
My dream!!
But I need to win the lottery or sell my house for a profit, neither of which are going to happen as I don't play lottery and I bought when everything was peak prices!! Lol
harryskid
Get a Honda! :)
BlueBolt
  On 7/31/2012 at 4:49 PM, harryskid said:
Get a Honda! :)
Put a honda engine in the 205...
It's not a 205 then
GLPoomobile
  On 7/31/2012 at 10:56 PM, Miles said:
It's not a 205 then
Yes it is. It's just a better 205 :ph34r::lol:
kyepan
my my, we are feeling brave today steve!
Why are we all ignoring the original question?
GLPoomobile
How's it been ignored? There's been plenty of input. Replies have been possibly a bit vague, but then so was the question.
