richsmells
Sooo.... Anyone Own An Mx5
richsmells
I had my 306 written off (along with my housemate's 2 month old mini and 2 of the neighbour's cars) by a National Express coach at 3am.
The 306 was parked where the mini is!
I've been looking at MX5s after driving a couple, and i'm quite impressed. They're not mega fast, and I think I can handle the stigma. Does anyone own one or have any buying advice they could impart? :)
There's a few threads already somewhere.
Kyepan, base-1 and Anthony would each offer you a haircut. ;)
Never mind the MX5, what about the accident, fook me!!
Back to the MX5, never owned one but driven a few, great drivers car without a doubt, personally I much preferred the 1800 with a bit more go to it than a 1600.
One major problem though is rot, one of our lasses work colleagues has a 2004 fixed light model that has just had to have sills etc, rubbish really on an 8 yr old car.
I've got an early Mk1 Eunos Roadster (JDM MX-5) and it's fantastic :D
Ignore the image and they're a lightweight, balanced RWD chassis with a revvy engine. What's not to like?
The single biggest issue that you need to look out for when buying is rust, primarily on the rear quarters and the sills, as they're terrible for it - UK cars seem to be worse as they've endured more of our winters, but many of the imports are looking just as bad now.
Mechanically they're pretty strong and fairly simple to work on. Import Eunos's are usually higher spec - PAS, AC, LSD etc often coming with them, often modified, whereas UK cars are often quite sparce. Early 1.6's (116hp) or the 1.8's (130hp) are the ones to go for on Mk1's - avoid the later detuned 1.6 as it's pretty gutless. Mk2's you really need a 1.8 given the extra weight - earlier are 140hp and later 146hp with VVT.
Economy wise, some people claim that they're uneconomical, but I've averaged over 34mpg from mine which is quite reasonable.
If you do a search I've written more in depth fairly recently when someone asked.
If it's a Mk1 that you're looking for, I'm likely to be selling mine shortly if you're interested? It's not standard (wide arch, suspension, 4 branch etc) but is solid and rust free, low mileage with 53k on the clock, and was only imported in late 2007 - I love the car, but too many toys and not enough play time or space in the toy box :(
tri_longer
The Hillclaimb & Sprint Association run a class in their championship just for MX5's, its well supported and had produced an overall championship winner for the last 3 years. All of the runners really rate their cars, there are plenty of options to make them handle even better and you have bullet proof mechanics. Stuff the image.
chipstick
Too many toys and not enough play time or space in the toy box :(
Brilliant quote!
kyepan
What anthony said, fantastic cars, wish I could use it more.
richsmells
Thanks guys. My cousin owns a late Mk2 1.8 "s" fixed light model with all the toys. I've had quick drive and I like the feel and steering feedback.
I'd probably be looking to get something similar, and there seems to be loads about around £2.5 - 3k range so I can afford be picky. The rust worries me a little but I guess i'll just have to look carefully and have a poke.
Regarding the accident, I was fast asleep at 3am, as was the coach driver apparently. Having a nightmare getting a courtesy car as i'm out of the country next week and they won't let me leave it at Heathrow so have flatly refused to deliver me a vehicle! <_<
Regarding rust, the sills (and I believe rear quarters) rust from the inside out, so by the time that you can see bubbling it's already pretty far gone - it certainly isn't a "quick rub down and bit of paint" that some sellers would have you believe.
The first part to go is usually the rear 12" of the outer sill, followed by the rear quarter in front of the rear wheel. Wheel arches (particularly the rear) can bubble up too, and the rain rail (can't remember the exact name for it) rusts out and soaks the boot too - but not 100% sure if that is an issue on the Mk2 as the roof frame is slightly different.
£2.5-3k should be plenty to buy you a tidy rust-free good example of a Mk2.
I would suggest driving a Mk1 as well - not only do you get the wonderfully phallic pop-up headlights, but they seem to be a better (more focused) drivers car than a Mk2/2.5, probably at least in part due to them weighing less. They're not as well sound deadened or as relaxed on the motorway though, so it's horses for courses really if it's going to be a commuting tool.
kyepan
Having said that, a mk one with a decent turbo conversion, properly done would be a weapon... watch out though, they tend to like megasquirt.
eddie bullit
I've got a mk2.5 1.8. With LSD, leather, hard top in a bag for bad weather. Need revving but handle amazingly well. Rust is the Achilles heal though as said. Check in front of the rear wheels on the cills, arches and check that the hood drains are clear. Reliable mechanically/electrically. Also can't bust the engine if the Cam belt snaps..which is a plus as its non interference.
Edd
richsmells
Great. Will hopefully have a look at a few when i'm back from holiday.
Also. FWIW NEVER user Tesco car insurance if you require any standard of customer service. :unsure:
backroadpug
We just supercharged a new style one a few months back. first one supposedly with this cosworth developed kit. was really fast but its still a bitches car.
BlueBolt
My mum (64) loves hers!!
changingman
Ive owned a couple of 1.8 eunos (import MX5s ) cos they have the limited sliff diff,both were bullet proof enginewise and took whatever anyone threw at them,i used to hire thyem out for track days.
Unfortunately,one of them didnt take to kindly to being rolled from bonnet to boot,thats right bonnet to boot two times!!
The engine however lived on in another mx5!!!
To sum it up,i cant fault them!
dave richards
What the hell was that filmed on, a camera phone from 10 years ago?! :wacko:
more than likely
MiniGibbo
I heard you can't buy an mx5 unless you like to smoke pole..?
MiniGibbo
I have two cars with tesco's and find them great..?
Is that like spending the evening grunting, straining, posturing and showering together with other sweaty men?
Sounds like an MX-5 will be right up your street then ;)
  • Like 6
custard-rallye
Ha ha owned !!!!
custard-rallye
My eunos s-special total go-kart since i fitted hsd coilovers plus torsen LSD is nice as STD
kyepan
That's a rumour mx-5 owners spread to keep the knuckle draggers out of the scene. ;)
