Simes
Testing Coolant Warning Light
Simes
Hello,
Is there a way of testing that this lamp comes on?
I've tried bridging the contacts in all combinations at the sensor end but to no avail.
Edited by Simes
ade 4wd
Do you mean the high water temp warning lamp, if so simply pull the wire off the sensor and connect that wire to a good earth point. Warning lamp should come on.
Simes
Hi,
Water level in expansion tank.
Phase 2 btw.
