harryskid 193 Posted July 1, 2012 Any one ever tried this, sorry its in German Share this post Link to post Share on other sites
Slo 283 1 Cars Posted July 1, 2012 (edited) cant see that lasting long on moving parts and certainly wouldnt try it on suspension components for obvious reasons. if you welded some steel together with a mig welder and you ended up with parts stuck together with "birds*it" it wouldnt last 2 minutes. to fuse metal you have to melt the 2 faces together this soldering is just glue'ing em together i would of thought Edited July 1, 2012 by Slo Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted July 1, 2012 I'm sure it would be OK for certain things, but you are effectively gluing the alu together using another metal as a jointing agent. The joint will only be as strong as the bond between jointing agent and the alu. When properly welding alu, the joint is as strong as the parent metal. Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted July 1, 2012 is that like ally braizing? i did have a go at this some time ago but its bloody tricky. ally melts real quick Share this post Link to post Share on other sites
harryskid 193 Posted July 2, 2012 I was thinking it might have its uses for sheet metal. I don't think i would trust it on main structures! Share this post Link to post Share on other sites
Liquid_106 97 1 Cars Posted July 2, 2012 Saw this sort of thing demoed at a recent kit car show. The butt joint between the two pieces of ally 'welded' together was stronger than the original material - we had a go at it till the ally failed, but the joint was intact. Was wondering if it could be used to fill in curb gashes in the various sets of alloys I have - don't own a TIG, which would be the accepted method. Share this post Link to post Share on other sites
Liquid_106 97 1 Cars Posted July 2, 2012 This was the stuff http://durafix.co.uk/ Share this post Link to post Share on other sites
harryskid 193 Posted July 2, 2012 This was the stuff http://durafix.co.uk/ Looks good i think i will give this stuff a try! Share this post Link to post Share on other sites
Rippthrough 98 Posted July 2, 2012 It's fine for panelwork and radiator repairs etc, don't use it for anything else though! Share this post Link to post Share on other sites
harryskid 193 Posted July 7, 2012 Found out a bit more, this was developed by the Yanks because of the Afgan war where transporting normal welding gas was too dangerous. Low heat, like butane is not so bad for field repairs and the guy tells me it is very strong. I have placed an order for some and can't wait to get started. I can weld and being a heating engineer i can solder so i should get on alright with it. My first job for it is a custom made oil catch tank for my rally car. Wish me luck! Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted July 7, 2012 Was wondering if it could be used to fill in curb gashes in the various sets of alloys I have - don't own a TIG, which would be the accepted method. kinda like the old 'lead loading' they used to do before filler etc came about Share this post Link to post Share on other sites
Rippthrough 98 Posted July 7, 2012 Found out a bit more, this was developed by the Yanks because of the Afgan war where transporting normal welding gas was too dangerous. Low heat, like butane is not so bad for field repairs and the guy tells me it is very strong. I have placed an order for some and can't wait to get started. I can weld and being a heating engineer i can solder so i should get on alright with it. My first job for it is a custom made oil catch tank for my rally car. Wish me luck! Not sure where that came from but the stuff has been around under various names for many years before the war... Share this post Link to post Share on other sites
harryskid 193 Posted July 16, 2012 Given it a go, it works but its strange stuff to use. The rods are quite thin and every thing must be clean, also its a bit trickey to judge the temp of the alloy and you must not use the flame to melt the rod!. Remember it s soldering not welding. The stuff is as strong as they say and would be good for broken lugs ie Alternator lugs could be rebuilt or holes in gear box casings and also can be used for mending bad alloy threads.I overheated a work piece and blew a hole in it and the stuff filled the hole with no problems.The rods i used don't go very far and they are 18" long and quite expensive. I bought 10 and a small stainless tinning brush for £32 and soon got through them. On the up side though i'am pleased with how they work and will get some more for those sort of repairs i've said and like every thing the more practise you have with it the better it gets. Some thing use- full for the work shop and remember you only need an ordinary blowtorch so it would even be handy on board a service van! Share this post Link to post Share on other sites
Uberderv 6 Posted July 16, 2012 I have used it before to connect boost pipes together, block holes in inlet after EGR removal and make an adapter flange. Can get pics if anyone would like to see them Share this post Link to post Share on other sites
harryskid 193 Posted July 17, 2012 I have used it before to connect boost pipes together, block holes in inlet after EGR removal and make an adapter flange. Can get pics if anyone would like to see them Good to learn somebody else finds it usefull ! Share this post Link to post Share on other sites
Neil_xs 0 Posted July 17, 2012 Have heard about this stuff befor but have never seen an end result. Think I will stick with tig welding for now untill it's been out for a bit longer and seen more end results. Share this post Link to post Share on other sites
kee 22 Posted July 18, 2012 very interesting, as said above it's very similar to brazing and plenty of spaceframes have been stuck together by the power of brazing in the past. any pics of the work you did harryskid? Share this post Link to post Share on other sites
harryskid 193 Posted July 18, 2012 very interesting, as said above it's very similar to brazing and plenty of spaceframes have been stuck together by the power of brazing in the past. any pics of the work you did harryskid? Not to hand but i might get some at the week end! Share this post Link to post Share on other sites
Liquid_106 97 1 Cars Posted July 18, 2012 @ Jeff / Uberderv - do you think this would work well with building up damaged alloys? Share this post Link to post Share on other sites
