Iain-gti 6 Posted June 27, 2012 Hi, I have fitted Gaz coilovers to my car a while ago and im just sorting out the ride height, the rear wheels are level/little bit higher than the rear arches but the front i cant get close. With the coilovers fully wound down the spring is loose and is a pain to seat properly but even then its not level with front arches. Any ideas can fit smaller springs but seating them is going to be annoying. thanks Iain Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted June 27, 2012 how long are the springs? shorter springs might be the only way if the platform is already fully wound down and its not low enough. helper springs should avoid any extra movement when the spring is decompressed Share this post Link to post Share on other sites
Anthony 1,003 Posted June 27, 2012 Isn't this why you use helper springs? Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted June 27, 2012 ride height, the rear wheels are level/little bit higher than the rear arches It will handle like a sack of s*it that low. Aim for the wishbones to be horizontal and NOT pointing uphill to the wheel. Share this post Link to post Share on other sites
Iain-gti 6 Posted June 27, 2012 (edited) Ill have a look at the wishbone, where can i get helper springs/smaller springs from i looked on Gaz but couldnt see anything. Edited June 27, 2012 by Iain-gti Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted June 27, 2012 (edited) http://www.ebay.co.u...=item2c664363c7 something like that although my gaz gha's from the group buy came with a set already on Edited June 27, 2012 by johnnyboy666 Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted June 27, 2012 What length springs did you opt for? Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted June 27, 2012 Gaz supplied mine with helper springs fitted, might be worth giving them a call, but please listen to Tom, don't drop the car that low. You'll be a hazard to yourself and others. Share this post Link to post Share on other sites
Iain-gti 6 Posted June 27, 2012 maybe i wrote it wrong the wheel is about 1cm from the wheel arch. Share this post Link to post Share on other sites
