chipstick 382 1 Cars Posted June 26, 2012 I need to source a 7 pin brown plug and socket. I have found part numbers for the 6 and 9 pin variants, but not for the 7 pin. As a last resort I may be able to remove some from a breaker, but what I would like to know is the best tested method for removing the pins from the plugs without damaging the plastic plugs. Is it a case of a careful tug with some pliers or would it be better to push the pin where it is crimped from behind? I don't want to ruin a plug with trial and error. 1 Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted June 26, 2012 Thought I had found the blade holder, but was the blade holder in a diagram alone. Then found the following which I think may be what I am after: 6542 G7 7 Voies de 5 - Maroon Clip Holder 6541 A7 7 Voies de 5 - Maroon Blade Holder Should be correct. Share this post Link to post Share on other sites
Anthony 1,003 Posted June 26, 2012 Ryan (I think it is) has the part numbers of the various housings and pins in a link in his signature. To remove the pins, undo the plastic latch/retainer on the side and the pins should come out quite easily without damage. Share this post Link to post Share on other sites
