Be Box Rebuild/refresh/refurb Part Sourcing, And Be1-3 Part Crossover
blandy
Has anyone got a reverse gear to measure the thickness.?
You were right welsh I was tottally in the wrong place as said it's definitely input shaft related to be doing it in neutral. I've found the reverse gear is catching/rubbing on the input shaft gear. It almost appears my reverse gear is to thick?
Now I had both this box and a xsara box apart at the same time so almost hoping it's a incorrect gear issue. I know the shim will alter the height of the input shaft ever so slightly but it does appear as if it's to thick
have you got the reverse gear on the input shaft the right way round? the reverse gear itself has a chamfer on one side of the teeth too.
blandy
Yeah i did notice that. I also tried both ways a min ago to check but makes no difference.
The Reverse linkage was different on the xsara box but dont remember the gears being any thing different
Mine is 15.5mm thick im hoping theres a few mm difference but think im clutching at straws. Its definately the reverse gear touching though 100% as testing on the bench you can see it touching and with reverse removed its silent
Edit just re read your post i thought you meant the reverse gear. Ill go check on the input shaft now as could well be as i had it apart to replace the synchro
Edited by blandy
blandy
Looking at the picture you posted earlier in the thread of your input shaft you can actually see a differnce
Your pic
9C400E46-3E7B-4411-A4A8-FA52BDAE04E1_zps
My input shaft
BD51D5E4-7CA6-428B-B004-CF99AC964357_zps
not sure which detail you mean but don't forget mine was a late BE1.
blandy
from the bearing you have the gear then a gap - then the long gear - then a gap.
If it makes sense the 2nd gap (furthest from the bearing) on your shaft looks wider, My reverse gear is contacting all the time with the top of the "wider" gear section
blandy
32FBBECD-5172-4C2B-9883-27E193406728_zps
AB1B8479-87E9-4935-85AA-08B57C889E82_zps
blandy
Tried to highlight here
blandy
and this is mine as you can see the gap either side of the gear is quite different
blandy
Just checked service box and the reverse gears for be1 and be3 are different part nos 2381 50 and 2381 30
can anyone confirm if there is a difference in thickness
have you got the reverse gear that matches that shaft?
blandy
No infuriatingly I had all the bits sat around and chucked the box by mistake on Monday in the skip at work. On tues realised and went to find it and Sod's law it had been emptied
Is your xsara box still in bits? If so could you measure the reverse cog?
Or if anyone has a be3 input shaft and can measure the parts in the previous pic
Edited by blandy
blandy
Just a thought. Thinking of the origins of this box. It came from dixons infamous 306 which thinking about it started as a 1.8 306 .. could this be where the difference is comming from I.e id assume the shafts are original to that box
doesn't really matter where it came from really, its just a be box witb a 4.4 fd.
as for the width of the reverse gear, and the gap either side on the input shaft, that doesn't matter as the idler gear is in constant mesh.
what is important is that you have the correct gear to match the shaft and corresponding driven gear inbetween the 1-2 synchro, the tooth profile was changed at some point
blandy
As silly as it sounds which part does the gear run on when you say constant mesh? The only other thing I'm wondering is the reverse linkage in the box doesn't feel solid I.e the ball under the linkage seems a little week?
There's a zx box on eBay
https://www.ebay.co.uk/itm/272530248496
Could I remove the reverse gear and I put shaft out of this to ensure I have matched parts?
All this because I threw the wrong part out
what does your reverse driven gear look like? the one between the 1-2 synchro.
blandy
Not the best pic as not got box at home as is on a bench in workshop
8628D574-140E-4BE1-ACF1-86AEA548B352_zps
Also that would of been the original reverse gear in the box lol
blandy
Actually yes I do have a proper pic
1BF76739-49E1-4B8D-A966-A9716EC16F6F_zps
blandy
Looking at the old picture of when I stripped it its actually clear to see the teeth on the reverse gear at totally different to the one fitted now
I.e
7B1FB0DA-E405-4C89-9516-789A6A3266C7_zps
ahh yes, that's the two different types of tooth profile I've noticed, though never mixed them so I never knew if they were compatible or not!
so you have the square toothed one now which is making the noise and need the pointy one? I may have a spare.
I checked the BE4 xsara box and its the squarer profile
blandy
Brilliant at least it kinda solves the whole mystery as that's clearly what I've done wrong - put the xsara one in.
If you would have a pointy one that would be brilliant as that's all I need and the box is good to go
Slo
In the middle of doing this myself and stuck on removing the clutch arm. The bolt wont budge, have you got any tips on removing it?
17269242_10155950889457222_4256165_o_zps
if its the threaded type its an m7 thread, get a slide hammer attached and apply lots of heat.
that type is an interference fit so can be particularly stubborn.
Slo
Slide hammer? What and just yank it out of its thread? Coincidentally i've just bought a slide hammer.
It's the only piece of the box that wont come out, its bare after this and i can get on cleaning it.
the main shank of the pin is not threaded, only the exposed nose of it.
