jeremy
Sorry Another Bit Of Help Needed Please.
jeremy
Ok I have fixed my daughters car and prior to the accident it would shake initially through the gear stick at approximately 40mph then through the floor at 65 to 70 mph, but not really through the steering wheel. Now I did ask her to spend a weekend with me to fix it, however she seemed to think that staying over at friends was more important. I did hope that maybe with a new wishbone, and TRE I could be lucky and fix the shaking too. I have also had the cars tracking done by laser. So any help welcome. Sorry forgot to say it is a 1.4 206 manual.
Jeremy
Inner CV joint.
steve@cornwall
Sorry, Jeremy, I'm a bit far away to drag your daughter home.....
jeremy
Is that my answer or your suggestion? Any obvious ways to tell which side needs replacing? Thanks
jeremy
Oh do not worry she is 19 and has a full tank of attitude, so really do not apollogise! :lol: :lol: Keep her as long as you can. Edited by jeremy
It is my suggestion from previous experience, a 306 I owned years ago had the same symptoms. Does the shaking get worse when power is applied, but seems to go away when you lift off the throttle?
jeremy
Will test more tomorrow, as unsure if due to acceleration.
Slo
buckled wheel? ovalled tyre?
any whining or grinding noises on power or under lift off? but goes deathly quiet when stuck in neutral?
