stu8v
Go On Then Which Cambelt Kit Do I Have?
stu8v
I went to fit a recently bought cambelt kit, skf no. vkma 03235 and guess what it doesnt fit. the belt is longer and the idlers/adjuster are slightly different.
Let me guess there are about 500 variations?????
Or I've been given the wrong one.
Anyone have the correct skf part number?
which engine do you have?
stu8v
LOL too busy ranting.......
A 2002 Citroen VTS
dcc
assuming this is a VTS/gti6 engine, there are 2 belt types.
Also, when you time the engine, use an 8v bottom pulley to line up the timing marks, else you'll 99% likely bend the valves
stu8v
I've locked the flywheel and pinned the cam pulleys so hopefully no issues there
yours will be the later 137 tooth belt as standard, though the 136 with the manual tensioner is preferred, GSF do these kits much cheaper than most.
if you want to swap to the 136 from a 137 engine you need the stud that the tensioner sits on, 0820 17, and the bolt 6923 78, which is a normal M8-1.25 x 25mm long item with a washer under the head.
there's a few different types of idler pulley, some need a much shorter bolt, if its one of these make sure the bolt isn't bottoming out in the block as I've had some ever so slightly too long.
stu8v
Mmmm, right I'm off to count teeth I'll be back
stu8v
Mmmm I seem to have a 153 tooth belt?
God knows whats thats off.
Stern words Tomorrow!!!!
Cheers for the help
that'll be an EW10 belt kit, which to be fair was used in an 02 Xsara, just not the VTS.
stu8v
Oh, Right there going to get it now. LOL
