terrytibbs3
Gti-6 Gearbox
terrytibbs3
Hi All,
Just fitted a GTI-6 Gearbox to my XU10 engine, But I can only get 1st, 2nd, 3rd 4th and R.
Has anyone else had this happen before?
Bish
Daviewonder
Maybe you bought a GTI-4 box by accident?
  • Like 6
BlueBolt
How did you get on with this?? Did you manage to find the cure??
What made you go for the 6 box??
Batfink
I think the selector arm has dropped inside the box and this can cause an issue. Its been covered in threads of old....
BlueBolt
Am toying with the idea of a gti6 box or other boxes at the moment so the main question was the one about why he chose the 6 box...??
allye
Have to say I'm loving my 6' box. Its a little bit of a novelty having a 6th in a 205 and peoples reactions when you mention it! That aside (I'm by no means an expert or highly experienced) but the ratios seem lovely and well suited to the engine and that extra couple hundred rpm in 6th does make a difference when cruising, all the more so with my stupid noisy magnex system!
Steering lock isn't great as you know, but I manage absolutely fine, even now living int he centre of Weymouth. Its only a problem if you have to pull the cabby special U turn or take a tight mini round about.
Edited by allye
... or if you're attempting to follow Dan through Cheddar in search of the pub, eh Ali? :P
BlueBolt
So The 6 box ratio is good for the 6 engine in the 205...??
Am pissed off with my boggy power delivery given by my 1.9 gearbox, so something needs to be done with it!!!!
What's the CWP number on the '6 box??
Edited by BlueBolt
allye
Haha! Like I said, only the U turns cause me issues.
As said I'm no expert but the ratios seem great to me, no idea about the CWP I'm afriad, I stay clear of gearbox spec's, just too confusing!!!
Final drive is 19x75 / 3.94 on earlier (Phase 1) GTi-6 boxes and a slightly shorter 19x77 / 4.05 on later (Phase 2/3) GTi-6 boxes
BlueBolt
Kewl, so a 4.4 would be a good upgrade for a '6 box then?? Bring the ratios a little closer but without loosing the top end as its got the 6th gear...?? I've been told the ratios are pretty close between 3/4/5...??
It's not that simple to change the final drive on a GTi-6 box AFAIK - it can be done, but I believe that it's very expensive.
Just fit either an off the shelf 1.6 GTi or a Xsara VTS gearbox to your engine and enjoy it - both are a fair bit shorter than a 1.9 and will make the engine feel much more lively whilst remaining sensibly road useable. The difference between a 1.6 and 1.9 might "only" be 10% on paper, but it is a night and day difference on the car.
Anyway, this is somewhat of an off-topic thread hijack....
BlueBolt
Good point, apologies
chipstick
I was thinking that when I was reading Ali's comment :lol:
this! :)
I recently saw a minor mod someone had done to combat this, they drilled and tapped the top of the shaft so they could insert a bolt and hold it up.
Edited by welshpug
I'm sure the ratio's are the other way around, Will check thou and confirm
That's correct according to Servicebox Miles - 19x75 up to date 19970601 and 19x77 thereafter.
I've always put it down to Peugeot fitting a shorter final drive to compensate for the extra weight of the Phase 2 models, although whether that's the real reason or not I don't know.
The Rev limit is lower on the later models, that's my idea on it. Right or wrong who knows
Cameron
Bish bought the 'box off me and as far as I know hasn't taken any of the selector levers off for the arms to be able to drop down. The box worked fine when it came off the car, now for some reason it doesn't.. very confusing!
He'd put a breather on in place of the lift-up reverse cable by mistake, something I've done before and been unable to get a couple of gears, but taking this off didn't seem to help. Bish - did you take off both breathers and try it?
terrytibbs3
I've only got 4 gear, but it pull much better and seems more aggressive! I like it.
