dave205
Oil Blowing Everywere And Getting Hot
dave205
As most of you have probably know because of my other problem threads i took my turbo engined 205 for a spin earlier, got home and pooped the bonnet up to find oil everywere, seems to mostly concentrated around the dipstick area, cleaned it up and ran it on tick over, no oil?!
Drove it again and had oil everywere again so much be related to the engine being revved or on boost/loaded.
Also when i took the expansion bottle cap off it pushed a cup full of water out as if it was pressurizing, i'd like to hope these 2 problems arn't related but guess they probably will be!
I dont know were to start!! :(
Paul_13
If you undo the expansion cap when hot it will do that.
What is the history on the engine?
dave205
I drove it approx a mile and the gauge was over half way up, un did the bleed screw on the stat housing and no water came out of there?
114k with full service history, ran and drove fine before removal, head skimmed and new cambelt before fitting. All fluids changed.
Paul_13
Do you bleed it before you drove it? and the heater matrix hose?
dave205
Yeah and had water coming out of the bleed screw, is that right?
Sounds like either rings as when the engine get's some revs up you get blow by or the HG gone and same thing your getting compression into the oil ways
dave205
As above the rngine has done 1 mile since the head gasket was changed and it ran perfectly in the 406 before, surely the head cant go in a mile?!
was the head checked and skimmed, new bolts, gasket on the right way up?
Do 2.0 Turbo engines have a one-way valve to stop you pressurising the crankcase under boost? If so, that could be faulty or incorrectly installed.
dave205
The head was checked and given a cleaning skim. The gasket can only go on one way i thought, it wont line up with the water and oil ways other wise.
well, it can be fitted the wrong way, but as you say, the holes don't line up quite right.
the tab that pokes out should be on the rear side at the flywheel end.
Edited by welshpug
dave205
There is a one way electronicly controlled valve that connects onto the inlet manifold the other side used to go back into the air intake so ive put a breather filter on it. It made a blowing sound all the time before so i changed it round and it stopped, could it be as simple as me fitting that incorrectly? :/
dave205
I'll check that tommorow then, anything else to check whilest im having a loom round it?
miamibungers
The dipstick itself, of it's knackered around the top oil can leak from there?
(null)
The deck of the block can go out of flat too, I;ve seen this a few times now on the Iron blocks along with the odd crack in there for good measure
dave205
(null)
Yeah its loose in the tube, ive got a new one on order on though.
dave205
How does that happen then? Wereabouts do they crack?
dave205
Checked this today and its correct.
dave205
I also looked at this again tonight, when the car isnt running water comes out of the bleed screw hole, when its started it stops. When the engine is then stopped, the water starts flowing again. Surely this has to be an air lock?
