macaroni
Oil Delivery Pipes For Camshafts, Which Way Round?
macaroni
Yes, another stupid question...
While replacing my inlet cam, I took off the oil delivery galleries above the cams, but I can't now remember which way round it went!
Is the open end towards the flywheel, or timing belt?
Cheers,
Antony
Willem_Jacobs
16V >
Not sure what open-end you're talking about... Al ends are supposed to have 'nozzles' fitted leading into the cam bearings...
LH drive conversions are so easy..............
macaroni
Willem, I meant the open end of the U shape the pipes form and going by your photo I got it right. Thanks very much.
Willem_Jacobs
ah... Should be really obvious as the drill for the centre 'plug' will not be machined into the last (in front in pic) cam-bearing cover
@ Petert:
Starting out with a '90 peugeot 205 1.1 TU1m powered shell it was still quite a lot of work ;)
Edited by Willem_Jacobs
