j4mes205
Gti 6 Conversiin
j4mes205
Hi guys got a 306 gti 6 donor car on its ways was just wanting to know does gti 6 engine and box bolt straight in and do I need anything else cheers james
Daviewonder
It bolts straight in but you need to modify the exhaust manifold for clearance.
Daviewonder
You'll probably have issues with the master cylinder hitting the rocker cover too. You need to tilt the servo backwards and trim the timing belt cover as far as I know.
j4mes205
What driveshafts would i need
allye
GTI shafts, depending on what hubs you'll be using, also depends if you use the 6 speed, if so you'll need to change the diff for a 205 BE3 item but maintain the GTI6 crownwheel.
sambaileyw
Out of interest could you swap hubs to 306 items, and then run 306 driveshafts?
It's not a hub issue, but the length of the splines on the inner CV differing between early (205) and late (306/Xsara) diffs
There is plenty of info on GTi-6 engine conversion if you do a search, showing what you need, what issues you're liable to come across, and most other common questions.
You should find loads of pics in the projects section as well, Just make sure the belts done
and the water pump :)
Edited by welshpug
And tensioner/idler...
Spiky
dont forget to unlock the ECU, ingnition/or car runing, and unplug the ECU
if you no good with electrics, and loom can be found here
306 hubs give positve camber, so jsut stick with 1.9 hubs and drive shafts
tilt engine a little to fit, or modify the bulkhead (i done this way), or you can modify the exmanifold
tilt the servo on the pedal box, gives more clearance for the master cylinder
chipstick
I wrote a fairly detailed list of things needed in my project thread (link in sig). Have a nosey and if you have any specific questions for anything you are unsure of, drop me a message and i'l help :)
j4mes205
Thanks for replies guys it seems to be quite long. Winded to get it done sovmight have to sort parts and get a plan of action together
Just atm im having issues with driveshaft seals on a standard 205 1.9 ive replaced 2 seals gently on drivers side but still seems to leak am i right in thinking could not be driveshaft seal but it could be coming out of speedo cable input
Thanks for the help as a total newbie to 205s as came from subarus lol
Spiky
could be either really
best to get under there, clean all the oil off and see where it's leaking from
a test (if your brave) put on axle stands put in second gear start the car up and let it run on tick over to get the wheels going,
get underneath and see if you can see it leaking
Remember that the driveshaft seals need to sit a little proud - if you put them in flush, they'll usually leak.
j4mes205
Aha that could be my problem i have put them in flush its so frustrating that it isnt sealing i will have to fit a new one not flush and also have a look at the speedo cable the passenger side i replaced is fine thats the frustrating thing
use OE Pug ones, Never had a problem with those,
