Rob Turbo
Mazda Mx5 Buying Tips?
Rob Turbo
My brother is after an MX5 and has asked me to go with him to see one on Friday, is there anything in particular to look for on them?
It's a mk1 1.8 if it makes any difference?
Thanks,
Rob
BusEngineer
RUST!! Check the sills along the full length, drain holes from the roof block up and fill the sills and they rot from the inside out, front wings rust as do rear quarters usually starting at the arch lips and sill.
MX5OC and MX5Nutz are good websites/forums for reference
eddie bullit
As Busngineer said really. Mechanic and Electrics are very good..the achillies heal being rust. Theres a front and rear drain hole on each cill that should be checked periodically for blockage. The roof drains at the back of the seats can also get blocked. This can be checked/cleaned with the use of flexible curtain rail. Dont push to hard though as the pipe can become disconnected. Have a prod about on the cill in front off the rear wheels..quite a few have perforated from the inside and have yet to show through. Check out sites as mentioned above.
Edd.
As above, by far the biggest consideration on a Mk1 (and increasingly Mk2's) should be rust. Normally starts on the sill and rear quarter panel in front of the rear wheel, and given that it rusts from the inside out, by the time you can see it will already be in a pretty poor state. It is fixable of course, but it's a fair chunk of money to have it done properly and best taking your time to find a solid one.
Don't discount the earlier 116hp 1.6 version - it's not much slower than the 130hp 1.8 in the real world thanks to the shorter final drive, and I found it a more enjoyable drive as it's so eager to rev compared to the slightly lazy 1.8. Avoid the later UK 90hp 1.6 though, as it's rubbish...
As you probably know, there's two MX-5's out there - official UK cars, and Jap import Eunos models. Both have their advantages and disadvantages, but if it's a Eunos you're looking at, check with your insurance as some are won't insure them. Advantage of Eunos's is that typically they've usually higher spec, have spent less time in the UK and hence are often neither as rusty nor as high mileage, but there's still plenty of knackered ones out there and usually there's little in the way of history with them either.
Electric window mechanisms are a problem - strong likelyhood that they'll be a little slow (especially the passengers) but if they're so slow that they barely go up and down, chances are that it's going to fail and need replacing (about £60 part IIRC). Can be improved no end by taking the door to bits and lubricating the mechanism.
Earlier Mk1's had a proper oil pressure gauge, later ones had a fake oil pressure gauge that is bloody useless. Coolant temp gauge shouldn't get past halfway in normal use - if it does, then suspect the cooling system of neeing overhaul.
Check for oil leaks around the back of the engine - not a major issue, but needs to be addressed as it has a habit of causing the rear coolant hoses to fail. It's normally the seal on the CAS that's failed.
Mechanically they're tough and should be problem free. If it feels and rattles around like a bag of spanners, walk away. Handling should be excellent, with precise steering and well balanced - if it feels distinctly underwhelming, wallowy and loose, then it's probably tired and in need of a fair suspension overhaul which potentially isn't cheap when you realise how many bushes and balljoints there are (plus a full 4 wheel alignment afterwards)
Aircon on most Mk1's is the earlier gas that can't be refilled without replacing various bits to go to R134a or using an expensive alternative. Not a major issue as I personally don't see the need for AC in a soft top, but it is unlikely to be as simple as "just needs a refill" if that's what the seller claims.
As with any soft top, check the roof for rips and leaks. A new hood isn't mega-money, so don't discount a car purely on this if it's the right price. Mk1's have plastic rear screens as standard, and can go cloudy or split - you really need to unzip the screen prior to dropping the roof to prevent the later from happening. Some aftermarket hoods have a glass screen which is much better.
Ripped bolsters on cloth front seats are common, and leather can be looking very tatty by now if it's not been looked after.
Obvously the youngest Mk1 is now 15 odd years old, so the usual checks that you would do on any used car of that vintage
GilesW
I think the most imprtant thing to check for is that it's not a light blue G plater.
If so look for some god awful filling on the offside A post and some badly matched re-spray.
(wheeler dealers)
base-1
Pretty much what's been said. I'd always say get an import if it's not much hassle, because of the rust and spec (you'll struggle to find an import without LSD). I don't think the insurance is a problem, they just call them Mazda Eunos and it's rarely any more expensive. Mk2 and 2.5s are actually more of a rust trap than Mk1s so with the age they're reaching now they can be worse.
Very early "short-nose crank" 1.6 engines can give issues so get a long-nose if you can, but it shouldn't be a deal-breaker for a decent car, and as said make sure it's not a detuned s*itbox.
One thing with the coolant system - it's a load of s*it, so if he's going to use it on track or similar, make sure he does a reroute.
Sometimes the slow windows can be improved by cleaning the switches, but they're just not fast to start with so don't expect that. Mine are terrible, an actualy inconvenience, but they've basically not changed in the last 4 years, and I've not exactly been generous with lubing the channels etc (I've done that and cleaned the switches once.)
Despite what has been said.... they're bulletproof these things. Go forever if you keep fluids even 60% full and don't crash them! :lol:
dave richards
crank wobble on early mk1's
Rob Turbo
Thanks for all the info.
Apparently it's had new sills, I'm not sure if that's good or bad! If it's been done properly then all good, I'll have to have a poke around to see if I can find any clues!
The more I've been looking at them the more I'm fancying one for myself, would need a turbo kit or an engine transplant though!
Edited by Rob Turbo
dave richards
turbo kits from flying miata, iirc the compression is low enough to bolt a turbo straight to the engine
Rob Turbo
All their turbo kits seem to be for the 1.6, I'll have to do a bit of research on 1.8 turbo conversions.
Might have to put the zx9r back together and get it sold to fund an mx5, I'll probably change my mind and want to keep the bike once I've been back on it though!
There are turbo and supercharger kits available for both 1.6 and 1.8 models, there's just a bit more choice for 1.6 models.
BusEngineer
I do enjoy ours but, I also look at it about twice a month and think about selling it, its enjoyable but its not a keeper! Even if the other half says it is!
I would advise anyone to try one as i was a hater many years ago but they do drive as well as their reputation says they should, but you do look like a bit of a hair dresser in a standard one!! :D Ive never felt particularly manly when driving ours!
Rob Turbo
I'd probably build my own kit unless there was one going cheap, and a 1.6 would probably do me fine with a charger on it. My brother has his heart set on a 1.8, he won't be doing any engine mods past fitting an induction kit and a noisy exhaust :rolleyes:
He took a 1.6 for a test drive a week or so ago and said it was gutless, I'll have to show him how it's done!
Rob Turbo
Don't fancy a swap for a '98 zx9r do you? :D
kyepan
the early ish (non wobbly crank) 1.6's are arguably the best, nice short stroke revvy zing!
I may be biased as i have one.
Rob Turbo
How can you tell the difference between the good and bad 1.6's?
I don't know how to tell them apart visually, but the age and origin of the car is a giveaway - all JDM import Eunos Mk1 1.6's with a manual 'box were 116hp, as were UK spec 1.6's upto 1993. Post 94 UK Mk1 1.6's would be the lower spec 90hp variant.
(the 1.6 fitted to JDM import Eunos's with an auto box were about 10hp down thanks to lower compression and milder cams - so beware of anything that's had a auto-manual conversion. UK models were never offered with an auto AFAIK)
eddie bullit
One thing to remember is, I think I'm correct in saying, the clutch/gearbox is a weak spot on the 1.6 and needs uprating with the 1.8s.
Edd
kyepan
look at the bottom crank pulley, if it has 8 cut outs, it's a good one, if it has 4 it's a bad one.
However then there is the low power and high power variant.
I'm not personally convinced that the short-nose crank is actually a major concern and reckon that it has been blown out of all proportion on the owners forums - after all, there's many thousands of examples doing just fine 20+ years on and the issue basically stems down to it being less tolerant of poor assembly rather than it being a fatally flawed design.
Use a torque wrench and a new bolt as you're supposed to, and it will be fine.
Rob Turbo
Well I went to see it, it resembled a wooden greenhouse!
The sills were both rusty, even the one that had been "replaced" was a mess, it pulled to the left, the N/S wing had been resprayed and the bonnet didn't line up 100%, after telling him to walk away he was still trying to talk himself into getting it!
He did the right thing and walked away in the end, then when we got back he realised I'd saved his pennies and cheered up a bit!
Good call. There's enough of them out there that you can afford to be fussy.
BusEngineer
How much was it up for?
Mines a bit rough and ready but i didnt give a lot for it, the lads at work laugh at me saying its a cheap 'sports' car! :D
Rob Turbo
£1100 I think, there's one on ebay that's a bit rough around the arches, local-ish, short tax and test, for £800 or best offer, I think he's wanting me to look at that for him next!
BusEngineer
I gave £900 for ours so i was around the right money
