j4mes205
Gearbox Oil Leak
j4mes205
hi guys got a 1.9 gti think its 1.6 box well i changed the clutch and whilst i was there replaced genuine gearbox driveshaft oil seal as was leaking when i jacked it up. put it all together and it was fine couple days later it started to leak box oil out the new seal could this possibly be that i over filled the box ?
cheers james
more likely that the seal wasn't fitted correctly or was damaged when fitting the new shaft.
j4mes205
right ok it isnt that tight to the shaft is it meant to be ?
