bazil_205gti
Twin Fan Set Up
bazil_205gti
Hi
has anyone got a drawing of how to wire twin fans off 2 relays? also if anyone knows the feed cable from the fuse board its on a d reg phase 1 205, as there is no original feed at the rad. previous owner had a fused supply from the battery on a switch.
i wired in a single fan which comes in off a inline water pipe sensor but i took a feed of the main switch wire and now when the fans cut in theres some sort of back feed to the ecu and when i turn off the car it runs for 2 seconds befor turning off, (it only does this when the fans are on) also my earth for the fans is at the block where the head light is,could i be getting some sort of interferance there too?
any help would be great
thanks
Matt
