Ryan
Diode/resistor In Fusebox?
Ryan
Tucked behind my fusebox there's a black plastic holder with either a diode or a resistor in it (can't tell which without removing the glovebox and dropping the fusebox out of the way). Is this normal? I couldn't find anything on the Haynes wiring diagrams.
dch1950
Hi Ryan
Diodes used in this sort of area are usually used to de-spike relay coils. So, is it associated with an additional relay in, or around the fuseboard.
Dave
Ryan
This is the part I'm talking about:
It's not on any of the wiring diagrams. Is this a standard part, or has it been added afterwards? If original, what circuit is it fitted to (I can't put it out far enough to read the wire numbers)?
cRaig
Do you have aircon? Ive found something similar in the loom I am attempting to fit :)
Ryan
No, it was just a bog-standard 1.6 when I bought it. The only option fitted was remote central locking.
dino20vt
I've definitely seen one before and it could be to do with the driving lights but I don't know what makes me think that?!
dch1950
Hi Ryan,
was it a diode or a shunt resistor ?
Dave
Ryan
I pulled the fusebox out as best I could without unplugging everything, and it's a diode. One side goes to the relay in the engine bay (dim/dip relay?), the other side is connected to wire 32M, which shares a pin in the fusebox with wire 32. Neither of these wires are on any of the wiring diagrams.
ade 4wd
I can confirm it is a diode for the dim-dip relay.
