Guest Stainpain
Changing Driveshaft
Guest Stainpain
Im sorry if this topic is already on the forum but I can't search it on my phone :/
I am planning on changing my driveshaft this weekend but have been told its a ball-ache..
Just so I can be prepared, what tools and materials do I need? And any advice or common problems etc :)
Cheers guys!
depends which side, but pretty straightforward.
jack the car up as high as possible on one side, this will minimise oil spillage, a 2 or 3 ton jack will lift it enough not to need a pot to catch the oil at all.
you need 16+17mm for the lower balljoint, 30 or 35mm for the hub nut depending if its a base model/1.6 or 1.9, and an 11mm ratchet spanner or deep socket if its the right hand driveshaft for the hockey stick shaped bolts on the intermediate bearing.
large screwdriver for prising out the old oil seals ;)
oh and the Haynes manual covers is just fine.
allye
If you're changing the gearbox oil you'll also need the square drive tool for the filler and drain plugs, plus new washers. As WP pointed at change the drive shaft oil seals whilst your there, remember not to push them in too far!
