bobdylan_55
Common Failures On 205/309
bobdylan_55
Hi people,
I was hoping that you could help me produce a list of common failures on 205s or 309s.
Not fussed about how big or small a failure it is, anything and everything.
Many Thanks
Edited by bobdylan_55
allanallen
205 coin tray :P
jord294
rear beams ;)
bobdylan_55
Jord, could if possible you determine why exactly the beams fail? i.e. poor design or just general wear over time?
and the coin holder might sound funny but its the kind of thing im looking for lol.
cheers
allanallen
You writing a book bob?
bobdylan_55
lol nope, trying a new business venture.
beams don't fail, they just wear out :lol:
gti6 timing belts :ph34r:
brake compensators
corrosion resistance!
johnnyboy666
leaking heater matrix
noisy heater fan
rad fan temp switch dying
hubs ovaling
caliper bleed nipples seized/snapping
little posts that the interior wing mirror trim uses to atach snappng
interior plastics getting brittle
faded bumpers
disintegrating speakers
dead central locking
slow leccy window motors
I think you'd need to split this into categories otherwise its gonna get messy!
e.g; shell, interior, engine, running gear
and then youve got the thousands of faults which are inherent in old cars not just 205 specific
Leon
Shell corrosion:
Headlamp panel
Inner wing
Bulkhead to floor join
Leading edge of roof
Sill to 3/4 panel join
Under rear seats (above fuel tank)
Boot floor
Rear crossmembers
Above rear side windows
Door hinges (wear rather than corrosion)
Mechanical:
Driveshafts (weak)
Ovalled hubs
Rear beam seizure/wear
Caliper bleed nipples
Brake compensator
Gear linkages
Heater matrix
Electrical:
Heater fan
Temperature sensors/senders
General brittle wiring
Earth points (all)
Central locking failure
Gauge failure (fuel is usually the first one, corrosion at the pump end)
Trim:
Snapped mounting posts on arch mouldings
Brittle interior plastics
Coin holder pops open
Faded bumpers & exterior trim
etc!
j_turnell
Door pins
Seat Frames
Seat bolsers
Exhaust manifolds
gear linkages
Metal water pipe
Dash cowl cracking
Rust under rear seats
Headlights earths
central locking motors
boot trim cracking
driving light surrounds
Could go on forever, hope not too many newbies read this lol :D
Another classic that i forgot - Brown multiplug!
Edited by j_turnell
bobdylan_55
a few of you mentioning gear linkages. What exactly fails on these? Just pop off easy or?
Leon
They actually last a long time before the fail (pop off) - but they wear quite quickly and make the gearchange feel absolutely horrible.
Pugleyrich
Not sure if anyone mentioned it already, but phase 1.5-2 parcel shelf clips (by the rear seats)
BenC
Personal experience:
Dash top cracking - sun damage?
Gti seat bolsters collapsing due to the way you have to get in and out of the car.
Vacum sunroof failure - stuck shut
Noisy/slipping central locking motors
BenC
also going to add dodgy hinges on glove box lid and rev gauge fails quite often on turbo diesel models (tdc sensor).
Strictly_Derv
Everthing they'r French....
Dash tops don't crack from the sun, you don't HAVE to get in & out of the car like a clumsy idiot, glove box hinges aren't dodgy! What would you prefer, an intricate bearing that's waiting to fail needing expensive replacement? A lot of it is actually very well designed if you think about it, built to last whilst still being cheap to produce/replace.
This thread is a mine-field and possibly endless judging by the ridiculous replies so far, hence i think it's a silly thread in a way! Most of this stuff is rubbish IMO as it actually comes down to poor maintenance and un-caring owners; badly removed/refitted trim, some clips etc are inevitably only ever meant to be used once, etc etc.
So my addition by proxy;
EVERYTHING! :P
They're all 20+ years old. But do pretty well comparatively speaking, look at similar aged Fords/Vauxhalls. ;)
Gear linkages aren't a 'failure', otherwise you can count every single mechanical component or consumable on the car!! :rolleyes: The nylon cups wear/shrink/fatigue and no longer sit firmly on the balls on the selector arms, hence pop off easily... they're a consumable, as are rear beams, etc etc
u47sb2
Interior clock
Heated rear screen
Driving lamp surrounds corrode
Sunroof leaks
Drop links wear
johnnyboy666
Your point about 'poor maintenance and uncaring owners' doesnt really apply in this scenario unless people have owned the car since it rolled out the factory. The point here is that people who dont know the previous owners can get a good idea of what might need fixing/replacing.
erbs
my pug is 21 years old and to be honest so far its been wear and tear stuff that has gone wrong, its normal,i personally believe that the 205 is a pretty
durable car by today's standards, Peugeot's only saving grace is that all 205's bodies was galvanized so rust isn't too much of an issue, mechanical items
can be replaced, I'm just proud to be an owner of such a vehicle and hopefully have many years driving her :)
Edited by erbs
  On 1/21/2012 at 8:35 PM, erbs said:
Peugeot's only saving grace is that all 205's bodies was galvanized so rust isn't too much of an issue...
Wrong i'm afraid. Please don't post unless you KNOW something for certain, thinking isn't good enough, it's mis-information.
Where does it say that then? There is no 'scenario'. How does it matter how many owners a car's had?
How does that not apply?. If the 'point' here is as you say, then my offering stands; 'Everything'. That is my opinion.
A 'common failure' is not the same as stuff that fails as a result of poor maintenance, lack of servicing or careless ownership! - so can't really be servicable items as this is just a lack of maintenance and carelessness 'breakages' if you want to be picky. Hence i offered my reply in relation to the content of the thread, 'Everything' is a 'common failure' if we're not going to specify otherwise.
deathbringer929
noisy heater fan
hubs ovaling
faded bumpers
i've had every one of the faults you list on my 1.9 (all now rectified thankfully )except the hubs "ovaling" what are the symptom and causes of this?
Generally it's down to people not torquing up the clamp bolt (or not replacing it so it comes loose/stretches) which allows the hub to move against the wishbone balljoint pin, and quickly makes the round hole in the hub go oval and increases the movement. Once ovalled, even with the bolt torqued up properly it still won't clamp the wishbone balljoint pin properly, and replacement is generally the answer (although there are people that can machine and repair them now)
Symptoms are that the car doesn't handle properly and feels unpredictable to drive, particularly when cornering when you'll often find the car will suddenly swerve part way into the corner as though you've just snatched at the steering wheel.
