Daviewonder
How Long To Remove Dash Loom And Engine Loom?
Daviewonder
Hi All
As above really. I need to grab a dash loom with fuse box, engine loom and headlight loom etc (basically all the wiring from the front seats forward).
I'm just wondering how much time roughly I would need to put aside for this task?
(Phase 1.5 1.9)
Cheers, Dave :)
Edited by Daviewonder
Simes
3 hours max.
Dash out should take less than an hour.
Get the engine loom out first as the ECU plug goes through the buklhead nicely.
Remove the centre console
Drop the steering column (remove the wheel if you're bothered too). Once you've loosened the dash from the bulkhead it should come away nicely. and pull the dash forward.
Headlamp loom is straightforward.
Edited by Simes
dash out first, given it is bolted down on top of the ecu loom.
Strictly_Derv
Are you going up there today? I might be there at some point
Simes
Out of interest is that at Bridges = Pease Pottage?
Not been there in ages.
