bassline21
Turbo Wiring Identifying V.s.i.m And Maxi Fuse Unit
bassline21
can anyone please post a picture of the vehicle speed interface module and the maxi fuse unit? ive taken all the boxes and the harness from behind the glove as im unsure so ive definately got it. i wanted to put a pic of it up here of what ive got but cant figure out how to do it without photo bucket. thanks in advance
You only need the VSS sensor in the box, the other's just do the signal for the speedo/Cruse control
bassline21
where do i connect my vss to then? on my diagram it shows that the vss runs to the vehicle speed interface module then that goes to the ecu??
Daviewonder
You need to get a 3 pin speed sensor and piece of loom and connect it up like so-
bassline21
thank you. ive got the 3 pin vss already so im away. ill put some pictures up soon so you can see what youve all been helping me with. its my first full engine conversion and im well pleased so far!
It's the Dual VSS you need or you won't have a speedo unless you have this already, but the ECU just needs the signal and nothing else, the wire normally splits along it's length,
bassline21
yh i get it now. i brought the vss through a link m@tt put up. so should be the correct one.
