qwerty
Gearbox Advice Needed
qwerty
hi all
I have 205Mi16 on a 1.6 be3 box and I'm thinking of putting a xsare vts box in,
Ive done a bit searching but cant find the defo answer anywhere, can anyone tell me if the ratios are much the same?
any advice is really appreciated
cheers Mark.
qwerty
They will be a lot less frantic
cheers stu8v
Its just my 1.6 box seams to be pretty worn coz theres a good bit of play on the imput shaft
I'll stick wi 1.6 thought coz its for hillclimbs
cheers Mark
stick new bearings in if its tired, or maybe the 4.4 fd with the 1.6 gearset
Only at higher speeds from third gear & above, first is slightly longer, second & third are shorter than the 1.6 box.
The graph below is showing the comparison between the two;
Blue is 1.6 & red Mi16 / Xsara VTS box
g
qwerty
hmmmmmmmmmmm interesting
i want to do hillclimb and track days, and after reading thought spikes project a while back and seeing the success he had with 1.6 box i keep thinking i should stick wi my 1.6 box, for now at least :D
cheers Mark.
