TBC WEBER 45s
Morette Phase 1
TBC WEBER 45s
Well I got my phase 1 headlights and open the box and seen how big the indicator unit was how big! So I ponder for a bit and saw my mates mark 1 vw polo out came the tape yes! I found that it fits just under the red trim not to big not to small.Now for the question can you put 2 sets of dip beam units on a 1990 205 and pass the mot? I think I read some where that if you had a car befor 1991 you can. ........................4.........m........p.......h...........................
why?
because you'd lose main beam!
tri_longer
Mine use a H4 bulb in one of them anyway so I have dip and main in one and second ones I use as spots that switch on with the main beam.
TBC WEBER 45s
Sorry.dipped and main with side lights you no h4 bulbs x4
TBC WEBER 45s
Yer I am thinking geting rid of the one with just the main beam and puting a dip and main beam unit
Dont see the point as they will be aimed in exactly the same place whereas if they're the drive type they can be aimed anywhere.
TBC WEBER 45s
They will look good and 4 is beter than 2!:-P but will it do the mot
I don't understand what you mean 4 will be better than two? you have 4, 2 are driving lamps the other pair are dipped and main.
TBC WEBER 45s
Yer I am thinking of get rid of the driving lamps so when I put on my side lights I get 4 then when I put on my dip lights I get 4 and when I put on my main lights I get 4.Was the point it is more for looks
daneldridge23
im sure if you have main and dipp beams both working and at correct heights you should be fine
TBC WEBER 45s
hope so that is wot i am going for :D i think that 4 will look better than 2
BlueBolt
I'm confused about what ur wanting to do...??
Fit the polo lights into the 205??
Or fit another set of bulbs into the current lamps??
Or am I missing something along the line??
TBC WEBER 45s
ok then the polo indicator lights are smaller than the morette ones i have put them in the bumper and fit 4mm under the metal trim on the bumper looks nice on phase 1 you have to move the indicator on phase 2 you do not have to move them.The lamps you get are 2 units with side dip and hi and 2 units with just hi beam :D
Daviewonder
I wanted to do this with mine before I sold them. I recon a 205 with 2 sets of headlamps coming towards you would look pretty awesome.
TBC WEBER 45s
thank you :)you get it.So will it do a mot like this ?
Daviewonder
Yes it should as long as they're alligned correctly.
TBC WEBER 45s
how comes you got rid then :wacko:
Daviewonder
It was a toss up between the Morettes and a carbon fibre bonnet. I didn't want both as I think it would look a bit OTT. I've yet to buy the bonnet yet though :)
Edited by Daviewonder
TBC WEBER 45s
Cool I have got a automatic bonnet keep meaning to have it painted for the last 3years
Strictly_Derv
haha you'll be wel' jel' when you see them on my car Dave :P
There's 3 sets on ebay ATM though incase your interested
Edited by Strictly_Derv
Daviewonder
Probably will :( . I saw you car down Terminus Road today, looked pretty sweeet
TBC WEBER 45s
Have you got any picture?lets have a look then
james_pug
I thiink there's some confusion here I think he's on about the twin headlamps that replace the standard 205 indicators not morretes that use the original indicators. Below are morretes
