JoshGti
Motronic Octane Switch Resistor Values.
JoshGti
Tbh I never tested the lambda as I googled it and found so many differing opinions on how to test them etc I just thought I'd use the mixture pot as I knew it was good!
Any info on lambda testing and I can always give it a go as and when, I've got plenty of plugs and lengths of wire to add a lambda should I need or want too.
As for the potentiometer bits just pm me your address graham and I'll post them out Friday. I've got 4 spare pots and I'm sending 1 to welshpug but would be interested in keeping 1 justincase, if you've got a couple that need to be rebuilt then i could send you a pair of spare bits? Pm me and let me know.
What car is the lambda & ecu from & I'll check autodata for the tests.
g
