BlueBolt
Braided Hose
BlueBolt
Not sure where to post this question up so thought i'd put in here...
I saw a post on here the other day with someone's build thread, in this he had used braided lines from the brake mc all the way through...
Am liking the idea of this, it did look very tidy, and I hate having to use copper piping as it never looks as neat and tidy as it should (in my mind).
Are there any problems with doing this?? I thinking about doing the same with the fuel lines but have a feeling that there are bigger negatives to this idea...
My gti is going to be of the road for quite a while now, as I need to save up a lot before I can continue with bits, but wanted to find a few buys I can do to it in the mean time so I don't forget how much I love (and love to hate) her...??
There are many things on the small jobs list, but this is amongst them if there's not anything I'm missing that would make it a poor idea???
Problems would be the cost, not so much the hose itself but the fittings required add up.
BlueBolt
I've seen hose at reasonable prices, surely if I'm to replace the lines anyway then i'd need to be buying the fixings too, which should in theory not cost more or less than usual???
Or would I need different fixings to fit into the braided hoses??
As for the fuel lines, I know they go from flexible pipe to solid an back again under the car, so surely if I replace it to one length of pipe without the solid section I would need less fixings??
Edited by BlueBolt
Do not underestimate the cost to fit out a car in braided. The fittings are totally different and roughly £5 EACH as opposed to the flare nuts for copper which are 20p each.
You need a better reason than just "looks" to make it worth doing in my opinion, due to how much it will cost.
BlueBolt
Really???
Hmmm... That'll be why it's not something I've seen done loads before then lol
Still likin the idea though lol
No I just made that up. :rolleyes:
Yes really.
Check out this page as an example.
CLICK
Edited by Tom Fenton
BlueBolt
Yes really.
Thought as much lol
That's quite a bit of money for that lot!!
I'll have to price it up, mostly for my own amusement...
Off the top of my head, here is a list
10x1 to -3 male-male nipple, 8 off
12x1 to -3 male-male nipple, 2 off (for 1.9 type compensators, check thread).
Swivel 90 deg -3 elbow 2 off
Staight 10mm to -3 banjo 2 off
Banjo bolt 10 x 1 2 off
Copper washers as reqd
Straight swivel -3, 8 off
BlueBolt
Is that for both fuel and brakes??
Powers on here runs www.torques.co.uk
I priced up enough to plumb the fuel system on my brothers Saxo and came to around £200.
Unless its a gravel or road rally car then standard lines underneath with the usual braided flexi's will suffice, even copper lines inside will work just fine and keep the costs down significantly.
Braided line often never looks as tidy as the original steel lines, time practice and patience and you'll get the copper replacements looking just as good, use copper nickel if you want as its much stiffer and harder to bend up but stays put easier, costs twice as much as normal copper.
BlueBolt
£200?? Hmm... Ouchy's lol
Is copper nickel an option for the brake lines too??
AlexN
You can buy the braided hose fittings cheaper if you are willing to buy second hand. This isn't really a problem as all the fittings are reusable, but they may not be cosmetically perfect if that is what matters to you!
I bought the hose from torques.co.uk and the fittings from a mate who was stripping his old race car and Ebay. I definitely paid less than £200 for a full set of -8 connections for my fuel system and most of the -3 connectors for the brakes/clutch.
BlueBolt
That's a little more reassuring...
It cost my mate about £250 for the hose and fittings I used to do his brake system.
Ryan
Rally Design has the fittings for £4-5 each and hose at ~£5 per meter.
If running inside then you need Bulkhead fittings as well, I rarely use Braded thou-out unless spec'd by the customer. Or under the car all new clips
allye
Braided for show, copper for pro B)
Seriously though on a normal road car i would say its a complete waste of money and as said very expensive. Absolutly nothing wrong with copper and braided flexi hoses in each corner, you can make copper look just as good as original with some time and patience.
JoshGti
It's the lines to the rear that put the price up as you would have to make up a hose for either side of the compensator. Copper hoses aren't that hard to make look neat but I get what's being said. Instead of the hassle I've run braided from MC to front calipers and then a single copper line to the rear and used a "T" piece to run braided around the rear beam, only cost around £130 doing it this way which is including stainless fittings, not bad considering a Goodridge braided setup is about £60.
BlueBolt
That's still quite deer, but I see why you've gone this route rather than complete braided...
SimonJ
Didn't jonmurgie do this years ago, put up pics and discuss the cost? Don't remember the figure but remember being shocked.
Cameron
Handily I keep all my reciepts so can tell you exactly how much this setup will cost! :D
I did a single line to the rear brakes, through a lever-style bias valve, to a T-piece that split the rear brakes. It cost me £200 for all the bits I needed - valve, fluid, hose, fittings.
Fuel lines are much more expensive, a brake line fitting costs £4.50 sans VAT whereas a fuel line fitting is coming on for £20! Likewise the fuel hose is about 4 times the price of brake hose.
BlueBolt
Ok, so... Nice idea, which I think I'll shelf and keep for a distant time :) lol
harryskid
My back brakes are done like that and that part of it was done at a resonable price, a lot less then others have said !
BlueBolt
What kinda cost did yours come to??
