marcdimma
[engine_work] 205 V6 Project
steve@cornwall
Think I've sorted it with a bit more cutting of the front bumper to bring it forward.
I'vealso got my front crossmember tacked on and will remove the engine after everything's dry fitted then do a bit of strenthening.
got some nice shinny powder coated parts to go on. I've got my self some motodrive side mounted bucket seats does anyone have some pics or ideas on how to fit them? I thought about getting rid off the old mounts and fitteing some bars across to take the side mounts unless someone has a better way ?
Without seeming like the spelling / grammar police (left a lot of that alone :) ) It's just layout that helps make things more readable, and no txt-type word shortening. Many of our users do not use English as a first language, so it helps us to help ourselves - it's not meant in an unfriendly manner at all.
unariciflocos, does the above help at all ?
Edited by steve@cornwall
unariciflocos
Steve, as you already pointed out it's not the spelling or grammar that's making it difficult to follow, it's having this huge block of text with no punctuation and no separation of ideas or sentences. Usually just hitting the Enter key every now and then makes a reply more readable. I've seen this on most forums and I encounter the same difficulty in any language.
It was an exaggeration that I couldn't read the reply, it just takes a LOT more effort when the text is not properly laid out. And just to prove that it's not a language barrier thing you should know that I'm fluent in English, I work for a British company and can speak 2 other languages apart from my native one.
Now back on topic, I'm just trying to help. I ended up selling my almost complete V6 conversion and the guy I sold it to still has the exhaust and front suspension to sort out and it should be road worthy.
steve@cornwall
You've nothing to prove - from your posts i would not have any doubts about your language skills, or guesses as to your nationality - location means nothing there! And that you are being helpful is also in no doubt. We do, of course, have other members who are not as fluent in what may be their second, third or more language. Perhaps one of us is reading out of context.
marcdimma
sorry for my thread to cause a problem.Im a builder i dont use much writeing/typing materials last time i did was at school
No update on the covertion yet got a new arrival to my family my new baby daughter so all my time is with her
steve@cornwall
Don't think there's a problem...... Sorry if I interrupted the flow of your thread, all trying to be helpful, if maybe a little clumsily :)
marcdimma
LITTLE UPDATE
Not had much time on the car.done a few small jobs
got my 406 gear shifter (not fitted) any1 got some pics of the shifter mounted not got round to it yet so unsure of how its mounted
HELP needed with clutch system
got some news from dan on the clutch its been moded to be used with a cable not a fluids not got too much info if any1 has a clue will be great
rad and fans mounted front support bar is in just need some brackets for rad.Gunna fit a top cross bar for top of rad as ive got it sitting low
Gunna run my coolant pipe below my rad got a alloy pipe to use onto a u bend
Has any1 fitted a oil cooler to the v6 i know therers not a lot of room but if i can find the room ill sling 1 in
Also maybe a oil catch tank to help with the engines health ive got my battery space free so wanna fill i
Not got round to the master cylinder got a taperd plate to foit behind the servo to tilt it SLIGHTLY dont like the look of the butcherd timing cover
marcdimma
Finally sorted my rad and coolant pipes. Fitted the gear shifter but having trouble getting the blooding thing into gear only goes into 1st and 2nd
Sorted the clutch system out need to make a bracket for the cable but the idle control vale is missing so need that in first
the missing idle valve
Goliath
Are you using the gearstick you got with the conversion package? I had the same problem with only getting 1st and 2nd and it turned out I had the wrong gearstick (from a diesel 406 coupe I think) once I got the correct gearstick I could select the gears fine.
I have drawn a little image to try and illustrate how the clutch setup works with your modified gearbox...
Where the green box says 'Fixed', that is where you need to fix a little black bracket (you should have got with conversion) to the gearbox bolt directly inline with the clutch arm. I should be a funny shaped black bracket with a big hole in one end for the gearbox bolt to go through and 2 small holes the other end for the end of the clutch cable to go through. You push it through one hole, then double it back through the other hole, then put the bolt on the threaded end of the clutch cable.
marcdimma
Yes your right had a bit of head scrathing at first trying to sus it out didnt come with any bracket but ill be able to modify 1
ill try the v6 gear rods
thanks for the diagram
marcdimma
quick update
jobs done
clutch cable fixed
throttle cable fixed
gear rods n shifter fitted but wrong shifter so need too change for v6 shifter
coolant pipes dry fitted and modified to fit
rads n fans fitted/brackets made
driveshafts in.With plenty of clearance
subframe in and spaced off
timing belt cover cut for servo and master cylinder clearance
exhaust fitted
fuel pipes and filter fitted
custom top mount fitted
front support bar fitted
electrics ready too go already been modified to fit the 205
jobs left too do
need unlocked ecu
modifiy a slam panel
airflow pipe needed
egr valve needs fitting
lambda sensor needed
breather pipes need fitting
Havin a bit of a break with the v6 trying too get my blue gti sorted ill get some pics of them both up
Rob Turbo
I've got an unlocked ecu, or I can unlock a locked one if you have one.
marcdimma
pug paul has saved 1 for me.Getting xmas out of the way and ill get 1
marcdimma
got a few pics sorted got my 1.9 engine ready for pump n timing belt kit
sorted my intake pipe got the breather attached just need the air sensor fitting
these dont have egr...
marcdimma
sorry ment idel control valve got egr in my heads as mines gone on anotther motor
marcdimma
new update
finally got the v6 running sounds lovely shame i took it straight back out.Plans for engine are a quick clean n paint and powder coat a few bits
got engine cleaned for my blue pug and fitted.Have loads of jobs too do
Coolant system
loom
exhaust
interior
gti trim missing
bonnet needs painting
marcdimma
new update not had much time on the car.Work has been really busy
got most of the powder coated parts on the engine
powdercoated
headertank /washer bottle white
strut brace white
inlet manifold gold
thermostate housings yellow
strut top mounts red/gray
top engine mount white
sump gold
gearbox end casing gold
calipers and hangers gold
subframe satin black
track control arm gunmetal grey
throttle cable holder white
fitted new track rod ends
new pug sport 309 wishbones
all poly bushed
new anti roll bars
new wheel bearings
full engine service
new gearbox seals
carbon fibre enclosed filter
new strut top bearings
seat mounting rails are wldering in i made them out off unistute normaly used to hang/suspend aircon units .The new bucket seats i have are motodrive pro with repainted backs in white also fitted with sparco seat mounts
more pic too follow
StuF215
I always find it interesting seeing how these conversions pan out, everyone does them differently from the last person.
Are you going to leave your cam pulley exposed like that? I didnt have to remove any cover material for clearance although I did give the servo a little inwards 'persuation' where it rubbed :D
Stu
marcdimma
timeing cover was already chopped maybe u could help with coolant pipe issue
all rad hoses are sorted just got the thermostate to the header tank and heater matrix too sus
My issue is i have 2 outlets from header tank but yet 3 from near thermostate as u can see from pic the grey pipe was as an existing metal 406 pipe cut short.If im correct goes too lower header tank
v6013.jpgalso had some shiny new paint should have the rest painted next week
one (or two?) of those goes to the heater.
james_pug
Hi mark paints looking good, are you going to pugfest?
Ive just done the coolant pipes on mine and what I've done is take the one that's painted grey on yours and the one above it to the heater matrix and the top one in your pic I've taken to the bottom of the header tank, then on the header tank I've taken the small one from the rad to the top and capped the other outlet off like the gti6 conversions do. I think it's right I have'nt run it up to temp yet cause I've still got to do my exhaust.
marcdimma
Dont think i can make pugfest pal.Its a bit far for me costs a fortune i will be attending french car show only on foot :(
keep me updated on coolant system once shes run upto temp not started mine yet keep putting it off
My plan for pipers were too run grey pipe to lower header as on 406 that is the same then tee off to heatermatix then back from matrix too lower hose outlet then for the top straight too top header outlet
pfft, tell the dutch guys that! or the guy from Norway that drove hs 405 T16 over! the V6 will do better mpg than the 8 valver and most 16's ;)
marcdimma
Lol maybe so
Takes me 3 hours too get there .car won't be ready for pugfest any way maybe next year I might drive it
marcdimma
new update
Started refitting the painted parts
I finally run the car upto temp and fans kicked in fine coolant circulates fine
Was checking for leaks and never noticed how the sump site so low too the floor hope its a bit higher once i fit the dimma wheels
