erbs
Oil Pressure Switch And Sender
erbs
i have a part to fit which is an intermotor part no 50870 which is the oil pressure switch
then i see this intermotor part no 53800 oil pressure sender
can someone tell me what each one does please, N00B question i know but this all a bit confusing
swordfish210
Sender operates the gauge and switch operates the warning light
erbs
ok thanks
i need the sender unit as i have the switch, will the local motor factors do these?
swordfish210
Yeah they should do
erbs
well got a new switch and sender as it was showing low oil pressure when you start, the switch made no difference as no light came on i guess it must be the bulb, but when i changed the transmitter and started the engine the gauge shot straight up to 3/4 as before it lazily moved to 1/4 on the gauge so i'm happy that i have a sound engine and loads of pressure.
was thinking about overhauling the engine but now its confirmed that i don't have to.happy days
now onto the water pump and belt and tensioner :o
Edited by erbs
