erbs 42 1 Cars Posted October 29, 2011 i see on a thread where someone polished up the rear lenses and looked like new, how is this done? polish alone would not achieve this? Share this post Link to post Share on other sites
benny205mi16 19 1 Cars Posted October 30, 2011 not sure if it will work on lights, but friend has an old spitfire and the plastic windows on the roof cover had misted from the sun. He used some polish on a paint work mop and went over them. they came up good. Share this post Link to post Share on other sites
205_sunderland 4 Posted October 30, 2011 polish them and laquer them, they will come up good Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted October 30, 2011 I washed mine then T-Cut them, then polished them up with autoglym super resin polish, they came up like new. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted October 30, 2011 thanks for the advice!!!!! Share this post Link to post Share on other sites
harryskid 193 Posted October 30, 2011 Just normal car polish will do it ! Share this post Link to post Share on other sites
205_sunderland 4 Posted October 30, 2011 If there quite old looking id wash them in hot water to get all the moss etc out the inside and then you could go wet and dry route or just machine polish them to death. Lacquer,wet and dry, lacquer,wet and dry and after making them smoother and smoother with finer paper one quick machine polish and theyll look mint Share this post Link to post Share on other sites
GLPoomobile 958 Posted October 30, 2011 Being plastic, I don't think they would need lacquering. It's fairly common to polish plastic headlights, as they often tarnish and go dull on the lens, so it should be just the same for tail lights. So long as you don't generate too much heat you should be able to bring them back to a nice shine with normal polishing techniques. Of course you can lacquer them if you want, I just don't think it would be necessary. Share this post Link to post Share on other sites
Andy_C 50 Posted October 31, 2011 (edited) Bit of wet & dry then hand or machine polish and you're done. No need to laquer, Edited October 31, 2011 by Andy_C Share this post Link to post Share on other sites
Richie 32 Posted November 2, 2011 I'd never even thought about doing this tbh. Just had a go at my clusters and they look great with a wash / lick of polish. Share this post Link to post Share on other sites
Will Eastman 6 Posted April 12, 2012 Anyone done this with front clear indicators as mine are looking very shabby in comparison to my new headlights....? N what grit wet and dry would you use?? Share this post Link to post Share on other sites
Andy_C 50 Posted April 12, 2012 2000 grit best bet to start as easier to hand flat & polish etc. Will work on any plastic lights TBH but worth thoroughly cleaning the insides too while you're at it. Share this post Link to post Share on other sites
MiniGibbo 142 Posted April 12, 2012 As able wet and dry then go mad with the polish. Can wax them too.. Share this post Link to post Share on other sites
jonny6 8 Posted April 12, 2012 done it loads of times . , 1500 on the DA, (wet ) , can even sand away the writing on them . and then polish up using fast cut compound and a mop . medium head . will look brand new ! Share this post Link to post Share on other sites
