qwerty
[trackday_prep] 205 Mi16 With A Track/hill Climb Future
qwerty
updates time :D
just a small update with couple pics to look at
I've been putting off taking the windscreen out but my mate was round the other day and he's don't the job a few time, 5mins later and it was out, not that bad of job at all really, the rear window was worse lol
I was really pleased to see how solid it all looked, only a small amount of surface rust on the bottom corner
qwerty
time for another little update :D
Cheers for comments by the way, i really appreciate them along with any advice :D
took the alarm out which i was a little scared off but still run started after i took it out so result :lol:
all propped up to drop engine out
removed this box section which was for radiator, it weighed a tone
think i might need a new rad :lol:
diesel gearbox out, and wont be putting that bk in a hurry lol not until i have at least 300bhp :lol:
was quite pleased i removed it by myself, wasn't even that difficult B)
its out, and exposed loads of wires and crap :P
more to come
qwerty
and the motor, soon to be cleaned up wi some new gaskets and a lick of paint etc
is this manifold standard?
started removing any unnecessary wire, quite a bit of weight saving i think :lol: makes the whole thing look a bit tidyed too, at least it will when am finished :D
and this is where am upto at the mo, really want to get as much of the wiring in the car behind the dash to keep a tidy neat engine bay, lots more to do yet though
cheers
Mark.
qwerty
little update
Been on with the wiring loom for a while now, very time consuming thing, tidied it up and got it ready to go bk in once the engine bay is removed of rust, seam welded, and painted, cant believe there was so much weight in the wiring i removed 3.5kg of it :blink: anyway heres couple of pics :D
A totally empty engine bay
Edited by qwerty
qwerty
Well not much to update on really,
Just been cutting away any unneeded brackets protruding bolts and tidying the rust areas in the engine bay, its mainly the sides of the chase legs that have suffered the rust in the engine bay, the front light housing panels have suffered quite badly so I'll need to cut them out replace them, how much would i expect to paye for them?
I'd put some pics up but its nothing you haven't already seen so I'll white till I've done a bit more.
So next jobs are- replace the light panels
seem-weld engine bay
prime and paint bay
buy a engine stand and start cleaning engine up
Few things to keep me going :D
thanks
Mark.
qwerty
Well it's well past update time :))
Truth is I've been a little busy, the car ended up taking a back seat for a while, my wife was setting new business up and I managed to get roped in on it so that was couple months gone the we started decorating the house etc etc
Hope to be back to the car very soon, here are a few pic of the progress since the last posts
Cleaned off the chase legs of the surface rust
qwerty
Then started a bit seam welding, this is the first time I've welded before so it's fare from perfect lol
Gave the engine bay a good de-greasing and general clean up to see what's what
Welded a patch in behind the headlight on the passenger side
qwerty
The other side was a tad worse
So cut it out and made some templates to replace the rot with some nice new shine metal,
qwerty
Next I marked up the tunnel to raise it up a bit to sort the clearance problems with the mi16 manifold angle,
That's about it for now, really wanna get back into it like before so will be back wi some proper updates a bit sooner this time :-)
Mark.
alexcrosse
looks good - but you should only seam weld with small stitches (1" weld, 1" gap etc) or it will crack.
qwerty
Thanks Alex, am pleased you told me that now as am about to do load more seam welding lol
Jus been out there on with it a bit today but the welder doesn't seem to be earthing properly so will have to see what's wrong, typical!
its not so much that it will crack, but if a crack does start it will keep going along the weld ruining the whole seam, unlike if you stich weld it'll just spoil the one inch or so.
what Rad is that? looks like a 306 one but I know they are a tad wide for a 205?
qwerty
Hi welshpug
I see what you say about the welding, it makes sens ;)
It must be the 405 rad coz when I've looked they don't seem to have a header tank and rad looks jus like mine, it was one of the most annoying things on the car when I use it as my daily drive because to check or top up the water you had to lift the rad bout an inch to get the cap off, you can see what I mean in this pic
I defo wanna update it with a nice new shine alloy one :-)
qwerty
Update time :)
I've been really busy with work and helping my wife set a new business up, so the car took a bit of a back seat for a while.
Thanks to the better weather and having a bit of free time, and following all your projects on here have been a massive motivation, I've managed to get back on with the project :)
I started by getting the turret strengthening plates and peddle box one made up at a local engineering company.
It was eather 4 or 6mm so I went for 6mm
All welded on and zinc primered
My welding is bit messy, I only have a small hobby welder at the moment.
qwerty
I spent a while with the wire wheel on the grinder cleaning and the engine bay, then I gave it a good few coats of zinc primer
Wire wheel on the grinded are great tool for getting every last bit of rust out, without taking any metal off, but there a vicious little beast, I made the mistake of taking the handle off the grinder so i could get in the corners easier, it kicked back at me on a sharp edge and got wound up in my T-shirt lol
qwerty
I cut a couple of rust patches out the floor where someone had jacked the car up in the past and pushed the floor up. Then went to work with the wire wheel on the grinder.
Bit more seem welding done and zinc primerd
qwerty
That's all for now, hope to get bid more done through the week, will get some more pics up as I go.
Mark.
qwerty
Evening all :)
I've got the car on its side, and I'm currently working on stripping the bottom of the car back to bare metal. I'm just looking for a bit advice on what to do with it one I have it stripped back, I'm using the magic wire wheel on the grinder :) fantastic tool!
My plan was to Hammerite Kurust the bad bits, zinc prime, 3M black underseal and then spray it body colour.
Am I doing the right thing or would you do anything different?
Mark.
Get some sealer on the seams before you cover it up.
Edited by welshpug
qwerty
Good plan welshpug
I'll have a look on net to order some seam sealer
qwerty
Little update
Got couple of my mate around the other day to get it tipped on it's side.
Took it out in the light first, that's the first bit of light it's had in couple of years lol
Few bits and bobs.
Didn't look as bad as I though one I had It on it's side and the light at it.
After roughly 4hours with the wire wheel.
Should get a bit more done Friday.
qwerty
Updates :)
I'll just let the pics tell the story, I apologise for my pics quality, I only have the iPhone for a camara at the me, and a gopro which the fish eye is sometimes a little annoying.
Kurust treated
I'll upload some metal work pics shortly
Thanks.
qwerty
A bit of metal work
I flattened a length of angle iron and plug welded it to tidy the seam
Much better :)
qwerty
Unfortunately I don't have a pic of this before I set to it with the wire wheel, but it all looked fine with the underseal and a rubber drain hole in the centre. I started to clean it out with the wire wheel and I was left with this big hole lol. So I made a bit of steel to fill it back in, I'll attach a mounting bracket for the rear bumper later
qwerty
A bit of seam welding and I welded all the small hole for the old brake line and fuel lines etc
And after a good coat of Zinc182 primer
I need to finish off the inside, fit seat mount and cage mount etc before I can give the underside a skim of filler and body colour it.
Next job is to fit these, picked them up for £35 which I thought was quite reasonable
That's all for now, I'll try and keep my updates a little less lengthy and more frequent lol
Thanks.
