Birdie
205 Gti6
Birdie
Hi everyone, thought i'd share some picks of my little pug, finally taxed and insured and had an awesome drive in it today.
Future plans are:
New exhaust system. (Not sure if i'm looking for a 306 or 205 system)
relocate battery to boot.
Been instructed to move the air filter.
Recaro's (buckets are abit harsh for my back)
May need some better bonnet pins also!
Edited by pug_ham
imagefilesizes, 160k max or use imageshack generated thumbnail codes as above.
scottypug
deffinatley movd filter lol looks ace though what do they handle like round corners ect with the gti6 lump in
scott
boldy205
Liking the Lazer Green! As said, dont like the 'puddle hoover!' much! I have a 6 im=n mine too, previously had a Mi, and 8v before that, i cant tell the differance round a corner with the 6 compared to the Mi. Maybe in just a crap driver!? :unsure:
Nice car, get some 888s and a slipper in it, then its fast round a corner!
Birdie
Thanks for the replys, the car handles really well, i've never had a 8v or mi so can't compare, alot better than my Punto haha. Going to go and give it a polish now and try not forget to take some more snaps.
allye
Looks good, your looking for a 205 GTI exhaust, a phase 2 one but without the cat. The down pipe needs to be cut and shortned because of the 6' manifold.
Birdie
Thanks for the info mate :) might get one custom made about 2.25/2.5".
got a few more pics today, only quick snaps!
I really need either an original bonnet or better pins for the current fibreglass one. Far too much movement above 70.
Uploaded with ImageShack.us
And yes i'll have a tax disc holder this week lol.
Birdie
Going to relocate the battery for more space, i've researched 3 items to use;
Oddysey racing battery.
0/2 awg cables.
Battery tray/box.
Can anyone help me with the rest if any? Going to order the equipment tonight..
harryskid
Looking at those pictures,has that car so much power its going into space :lol:
Birdie
LOL, i did rotate the pictures, but when loading onto here they just do what they please :o
I'm going to use standard battery to relocate, so going to need a decent closed box if anyone can shed some light where to buy!? I can only find ones at £100!
Edited by Birdie
Henry Yorke
the best way to do this is if you are handy with a welder is to cut a hole in the boot floor and have it as low down as possible. It may save buying a box!
Stu
Get to your local caravan place dude, they do battery boxes for a tenner or so, its what I run in mine, ill see if I can find a pic ;)
harryskid
Demon Tweeks page 380 boxes from £47- £60 plus vat comes with quick release fastners :D
Birdie
Thanks for the help guys, Found some cable and fuse on ebay at a reasonable price http://www.ebay.co.uk/itm/0-Gauge-Power-Earth-Cable-RCA-Lead-ANL-Fuse-Holder-Kit-/170709005680?pt=UK_In_Car_Technology&hash=item27bf0cb570
As for the battery i've been told to get a powervamp racing one, only thing i'm not sure about is, my current battery states 540 cca and 60ah, I've looked at the Powervamp PVR25 which has 680cca, but 18ah? Can i use that battery or not?
P_Monty
The 'cca' is cold-crancking amps - its the about of oomph it can supply to the starters that bit is fine.
The Ah is the amount of juice the battery actually stores. If for the save of argument, the starter draws 200Amps, a 50Ah battery will drive the starter for 1/4 hour (50/200) (probably less, as this all assumes the battery volts don't drop as the battery flattens) a 20 Ah battery will drive the starter for 1/10 (20/200) hour or 6 mins.
I suppose the question is, does your car normally start first go on the key, or does it take a fair bit of churning to get it going?
Birdie
It starts straight away, no hesitations!
But as i'm relocating battery in-car i want to buy a sealed lightweight battery, my current standard battery has about 580cca and 60ah, and a powervamp30 is about 850cca and 26ah and costs £130, Didn't really understand the ah at all, as long as i don't need to keep messing around charging it i'll be happy :)
Many thanks for reply's, Sean.
P_Monty
Ah is amps times hours so 10 Amps for 1 hour is 10Ah, 1Amp for 10 hours is 10Ah, 100Amps for 6 mins (1/10 hour) is 10 Ah.
Hope that helps...
Birdie
Hope that helps...
Perfect, thank you P_Monty.
so 18ah is good enough :)
Birdie
Ordered a battery, and got 4metres of 35mm welding cable.
Can anyone recommend a junction box & fuse holder, will a 150amp fuse be okie.
Sean.
Birdie
Not reallly keen on the current 6spd box, need either a xsara 5spd box, although i've read people are using 1.6 box's with 1.9 final gear ratio.
ellis
Nice bud. I can help you out with battery box if you get stuck, I can make posh light weight alloy ones :-)
Birdie
I've already sourced a bracket now mate, thanks though much appreciated :)
ellis
Cool get some pics up, would be good to see ya setup, I'm gunna do mine a well soon.
BlueBolt
PM'd!!! I'm looking to relocate my battery to the boot, but not for a track car, more for ease, and lots less cables for amps etc...
Pics of what you've got done with Battery would be good?? Both ends...??
Birdie
Birdie
Going to need to upgrade the bonnet pins sooner than i thought, one of them detached itself today haha.
