hd_andy 2 Posted September 15, 2011 (edited) Is anybody into older classics that require grease maintenance? I need to buy a grease gun (for use on an E type - not mine :-p) - I've never used a grease gun so I don't really know whether to go expensive. There are two draper ones on tooled up, one with a long handle thats about £13 and one thats a pistol type thats £48 £40 reduced to £13 £60 reduced to £48 Any benefit in spending the extra £35? Cheers Andy Edited September 15, 2011 by hd_andy Share this post Link to post Share on other sites
GilesW 41 Posted September 15, 2011 Think E types have grease nipples on the running gear. If you want to only ever buy one grease gun then get the one with teh flexi hose as the rigid may be a bit difficult to get on teh nipples in confined spaces. Or - check where all the nipples are and if easily accessible then get the hard neck one. Share this post Link to post Share on other sites
hd_andy 2 Posted September 15, 2011 Ah, good spot - i hadnt even noticed that! The E Type has some ridiculous number of grease nipples so I expect a lot of them are in awkward places. Share this post Link to post Share on other sites
lagonda 42 Posted September 17, 2011 Go to an autojumble, you'll probably pay no more than a fiver for a decent one. The only real benefit I see for the much more expensive one is that it's designed for single handed use. I've got both types (& other types...but then I like tools...also more than one grease gun is handy if you use different types of grease). The cheaper one will need the gun to be lined up more or less straight onto the nipple. I think it unlikely that the E-Type will have inaccessible nipples. I've never needed to use a flexible connector, the rigid ones have a crank in them which generally makes access possible. Nipple design also means the gun/greaser connector can still be used at an angle to the nipple. If all else fails, you should be able to buy a flexible connector for seriously less than £35! I did buy a gi-normous (and never used!) grease gun here in France at a vide grenier (car boot sale) for around £5, mainly because it did come with a flexible connector. Looking at the Draper items again, I see they have a flexible connector available separately for £6.82....so check that fits the cheaper gun, if it does, buy that & the connector. Share this post Link to post Share on other sites
omega 82 Posted September 17, 2011 as above get the cheap one and the flexi [it just screws in]and you will be able to do all the jobs. just make sure that before you use it the nipples are for grease and not oil! Share this post Link to post Share on other sites
