gaz832
Another Fuel Problem
gaz832
hey fols, having probs with the car again, last week the car gave up on me , so i changed the fuel pump and put the hoses on the correct way round , tried to start it but no fuel to engine, so i chandged the hoses aroud but still no fuel, fuel is pumping but not going to engine, could i have a blockage somewhere, only thing i havent chandged is the fuel filter could this be totally blocked and stop letting petrol though.
omega
think you have ansered your own question!
gaz832
anyone got an ideea to sort this, or had this similar problem .
harryskid
As he says!
GLPoomobile
Disconnect the hose from the bottom of the filter. If you've got fuel pumping through there, but nothing after the filter, then that's your problem.
If you've got nothing pumping out even before the filter, trace it back further.
gaz832
got fuel going to the engine now, now the damn thing wont fire into life. gotta love the 205.
harryskid
Where was the blockage?
gaz832
in the fuel lines mate. once i got petrol to the engine ,there was loads of prssure to it, actually blew the hose off the regulator. . now it wont turn over. . i recently removed a aftermarket steroe and put the origional clarion in, dont know if ive cut a wire wrong or not, as it was starting before i took it out. now it wont fire up, turns over no bother . checked the plugs just had new leads, but it was playing up lately. new rotor and coil time a think.
gaz832
should petrol stay filled up in the regulator if its not starting, . just thought if the fuel rail is clogged up now.
Mark Greenwood
the pressure will stay there yes
when you say it will not turn over, do you mean physically..? Has it filled the bores with fuel?
dcc
double check your fuel pressure regulator. if its not working at 3bar (from memory so dont hate on a player for wrong info) the injectors wont feed enough fuel into the engine
